Suspension & Brakes Theory, alignment, spring rates....
Help diagnosing a problem
Old Aug 29, 2010 | 09:32 AM
sonicseaweed's Avatar
Default Help diagnosing a problem
I have a 1998 Civic Aerodeck 1.5L 5-door.
Sometimes it will suddenly pull to either the left or the right. It will also intermittently make a light repetitive sound from the front left wheel. No vibrations are felt, the sound from the front wheel is only audible if the window is opened. If I tug on the wheels suspended in the air or not I can not feel any play. The steering is responsive and does not have any gaps/play. I cannot visually see any cause and I am at a bit of a loss.
The springs are in good condition as are the shocks. I have replaced the rubber fittings for the shocks and that changed nothing.
Any thoughts are welcomed!
Old Aug 29, 2010 | 10:00 AM
el crapitan's Avatar
Default Re: Help diagnosing a problem
try swapping wheels from front to rear. probably won't do anything about that noise, but may help towards pinpointing the choppy steering. and it won't cost anything to do
Old Sep 2, 2010 | 07:20 AM
yomandude's Avatar
Did you try moving the wheel in all the axis? or just tugged on it? could be a bearing, could be the tie bar or simply the tires...
ribal_gh
Honda Civic (2006 - 2015)
Mar 31, 2015 10:47 PM
vipermax
Aug 10, 2010 06:32 AM
Ace of Spades
Jan 13, 2007 09:36 PM
Weapon_R
Feb 25, 2005 11:09 PM
menappi
Jan 13, 2004 12:35 AM
