Does the asr 24mm sway bar with brackets bolt onto function7's 96-00 subframe brace?
So right now i have f7 rear lca's, asr subframe brace, asr 24mm swaybar. A buddy of mines really wants to buy my asr and I do like the look of the f7 subframe brace. So I wanted to know if anybody has tried using the asr 24mm sway bar and polished D-brackets with the new f7 subframe brace? This is on the 96-00 civic chassis by the way. I dont want to have to use any universal D-brackets i want to be able to use the asr sway bar and hardware bolt it up and go. Thanks in advanced.
Re: Does the asr 24mm sway bar with brackets bolt onto function7's 96-00 subframe bra
It should fit. We've seen pictures of customers sporting the ASR D-brackets with our braces.
Any brand sway bar will work with our braces. If the supplied D-brackets do not fit (which is a very rare scenario), you can get the universal sway bar brackets/bushing kits (Energy Suspension kits) from us that accomodate any size from 11mm to 35mm.
We usually carry the standard/common bracket & bushing kit sizes in stock (13, 19, 22, 23mm) and for any other size it's a special order - the cost is somewhere around $25-$30 for a pair. You can also order them from Energy Suspension directly (we'll be glad to give you the part # if you know what size you need).
-A
