Suspension & Brakes Theory, alignment, spring rates....
Brake problem
Old Sep 20, 2010 | 07:37 PM
warzo69's Avatar
Default Brake problem
I have an 88' crx with rear disk brakes. The car was off the road for approx 18 months. Now for the problem, when I push the brakes they go all the way to the floor. I attempted to pump the brakes to see if they were leaking somewhere and could not find a leak. I changed the rear wheel cylinders and bled all 4 brakes. I cant see fluid leaking anywhere. What should I do next to diagnose whats wrong? Any help is greatly appreciated.
Old Sep 22, 2010 | 12:56 PM
Gekko's Avatar
Default Re: Brake problem
If you aren't feeling any resistance when pressing the pedal down I'd check the master cylinder. The seals could be worn out and just letting the fluid pass by.
Stance Movement
Jul 30, 2018 08:16 AM
-iLLuZioN-B18C1
Jul 13, 2009 12:16 PM
namax
Jul 16, 2007 05:43 PM
Jose-aka-Pedro
May 18, 2006 03:25 PM
