Suspension & Brakes Theory, alignment, spring rates....
spring rate help!
Old Oct 20, 2010 | 06:31 PM
blown_ss's Avatar
Default spring rate help!
ok so i hate my skunk 2 set up because they are too stiff. i've done some research and im really considering GC coilovers. i already have brand new after market shocks so i will be using them. here is my issue, my car will not be used for any kind of track or drag racing of any kind. i enjoy a lowered car and thats it. with that said i was considering 200lbs rear and 300lbs front or 250r and 350f. my car is a eg with a b series swap and i want the smoothest ride i can get with coil overs. so which would you consider? thanks for your help.
Old Oct 21, 2010 | 05:42 AM
blown_ss's Avatar
Default Re: spring rate help!
can i get a little help?
Old Oct 21, 2010 | 07:46 AM
alphalanos's Avatar
Those rates sound ok. Id go with 400f 300r probably. But if you want a little softer ride the rates you picked would work. Anyway you can always get new springs they are cheap.
Old Oct 21, 2010 | 10:47 AM
blown_ss's Avatar
yeah i just want the best ridding car that i can have with coil overs. i drive 50 miles to work one way and the roads in atl suck! where could i pick up the springs instead of buying the whole setup? i al ready have the skunk2 sleeves so if i could just change the springs that would be great.
Old Oct 21, 2010 | 11:18 AM
rick_rabies's Avatar
I'm not Rick!
what are the spring rates for the stock springs on an ek/eg/dc?
Old Oct 21, 2010 | 11:25 AM
blown_ss's Avatar
thats a good question. i have no idea.
Old Oct 21, 2010 | 11:26 AM
I'm not Rick!
a search on here has loads of threads asking but no info
i found this though
RANDOM INFO FROM OTHER THREADS ON H-T
96-00 EX - 165F/80R
eg was 250 front and 150 rear
accord front 180, rear 140
All tegs 'cept for the R have 212 lbs front rates and 117lbs rear rates
http://www.team-integra.net/sections...?ArticleID=747
prelude F: 180-200 R: 120-175
s2k Stocks are 218 FR and 291 RR.
Old Oct 21, 2010 | 11:32 AM
I'm not Rick!
^sticky this
Old Oct 21, 2010 | 01:21 PM
98civdx's Avatar
Master Detailer
Eibach will sell you ground control srpings sepertly, at about 60 a spring
Old Oct 21, 2010 | 02:12 PM
kristo's Avatar
Loved
What are "srpings sepertly"
Old Oct 21, 2010 | 02:13 PM
kristo's Avatar
Loved
I want one too
Old Oct 21, 2010 | 02:17 PM
kristo's Avatar
Loved
EK9 is 240L/P, and being a Type-R it would hardly have less stiff springs than an EG, let alone an EG having stiffer springs than a S2K.
Old Oct 21, 2010 | 04:37 PM
blown_ss's Avatar
i found this though
96-00 EX - 165F/80R
so with this info above i should shoot for some 350f and 250r to have a ride near stock since the car is lowered and the spring will need to work a little more to not bottom out. my main problem now is my rear springs are so stiff any bump i hit is hard and bouncy. my front springs seem to be ok but i would like to go a little lighter so that my car will do more of a flow instead of a hard bounce.
Old Oct 21, 2010 | 07:24 PM
98civdx's Avatar
Master Detailer
I was on my phone. and ride in a boucny *** civic lol
But what i meant is you can buy single springs.
Old Oct 21, 2010 | 11:10 PM
kristo's Avatar
Loved
Just joking, buddy
Old Oct 22, 2010 | 12:29 AM
kawika219's Avatar
you might wanna consider rebound rates, sometimes if your springs are to soft your shocks will bottom out
Old Oct 22, 2010 | 05:02 AM
blown_ss's Avatar
bottoming out would be a better ride then what i have now. im not going too soft but i want something close to factory so that the ride is better.
Old Oct 22, 2010 | 06:19 AM
tlarimer's Avatar
I am absolutely happy with my ITR shocks and springs. I installed last week and the ride height is 1" lower than OEM, but retained factory ride quality. And the price was better than a set of new springs.
Old Oct 22, 2010 | 08:51 AM
blown_ss's Avatar
i like my car low. not slammed but low. i have 16s and i tuck a little tire in the front and rear. no stock springs would make me happy.
Old Oct 22, 2010 | 09:00 AM
tlarimer's Avatar
Well to each their own, I was just throwing another option at you. The ITR suspension suits my needs, wants and taste for my car.
I ride on 15" wheels and I have right around 15/16" to 1" of wheels gap.
Old Oct 22, 2010 | 01:02 PM
blown_ss's Avatar
thats cool man. thanks for your input. i figured out what springs i was going to get and i ordered them from summit since they are right down the street.
Old Oct 22, 2010 | 01:38 PM
98civdx's Avatar
Master Detailer
What did you end up getting?
Old Oct 22, 2010 | 02:07 PM
racebum's Avatar
most spring rates are listed at team integra in an article. no linear spring will be as nice to drive down the freeway as a progressive. if comfort and better handling are your thing the tein h tech is really hard to beat. progressive and slightly stiffer than the oem itr rates. it's literally the spring the 94+ integra should have came with from the factory.
with coilovers.....you can buy whatever rates you want. comfort is subjective
Old Oct 22, 2010 | 02:12 PM
kevinm1981's Avatar
ots rates i recommend. 380 front 250 rear.
Old Oct 22, 2010 | 05:04 PM
kawika219's Avatar
post some pics up with the end results!
