Suspension & Brakes Theory, alignment, spring rates....
Caster issue
Old Jul 8, 2013 | 04:06 PM
spotrep's Avatar
Default Caster issue
1997 Honda Civic LX
After getting an alignment (I was suspicious that something got messed up) I came to find out I have negative caster on my front right (passenger) suspension. The front left is within spec at +1 degrees, but the front right is way out at -2 degrees. After looking for a bent control arm, I found nothing. Is it just a fucked up ball joint? What am I missing here?
Old Jul 8, 2013 | 04:28 PM
TunerN00b's Avatar
Default Re: Caster issue
Originally Posted by spotrep
1997 Honda Civic LX
If not a bent control arm, then the subframe that the LCAs bolt to could have been moved.
Any ball joint that "fucked up" would probably have obvious play and be completely noticeable without an alignment. The same should apply to any bushing destroyed enough to let the alignment move that far out of spec.
HyHondaRon
Honda Civic (2001 - 2005)
Nov 8, 2011 05:24 PM
Jaydeep
Aug 8, 2010 08:30 PM
shahriar35
Jul 10, 2009 06:30 PM
NoLipRacen
Jun 15, 2003 11:52 AM
