Suspension & Brakes Theory, alignment, spring rates....
suggestions on height difference??!!
Old Jan 4, 2005 | 02:34 PM
BDogggUT34's Avatar
Default suggestions on height difference??!!
When i bought the car it already had Koni Yellows and coilovers installed already. However the rear passenger side was higher than the rear drivers side. So i turned the bottom perch of the rear passenger side down a little and checked it, still too high. So i did this a few times and finally got them at the same height but the rear passenger perch is almost all the way to the bottom of the coilover while the driver's side is set about midway. What should i be looking for on this problem? I looked at it closely but i dont have enough experience to see what the problem is and what is causing the height difference? thanks
Old Jan 4, 2005 | 02:37 PM
Tyson's Avatar
Default Re: suggestions on height difference??!! (BDogggUT34)
if youre adjusting the perches, its not necessarily going to be equal front and back. and it depends on the length of the springs itself. so i wouldnt consider it an issue. thats why theyre adjustable.
Old Jan 4, 2005 | 02:47 PM
BDogggUT34's Avatar
Default Re: suggestions on height difference??!! (Tyson)
true, i'm gonna actually measure the height of the springs themselves and see if there is a difference there
Old Jan 4, 2005 | 02:51 PM
Tyson's Avatar
btw, what "coilovers" did you get?
Old Jan 4, 2005 | 02:53 PM
BDogggUT34's Avatar
came with GC coilovers when i bought it
Old Jan 4, 2005 | 03:11 PM
Tyson's Avatar
great, tell me the numbers printed on the springs, that will tell you the lenght of the spring, if you didnt know how to check already.
Old Jan 4, 2005 | 03:13 PM
BDogggUT34's Avatar
no actually i didnt, i'm at work right now so i cant check the numbers right now but i will definitely look at that.
Borokazan
Honda Civic (2001 - 2005)
14
Dec 11, 2007 07:52 PM
BDogggUT34
Jun 30, 2005 08:55 AM
AnitRiceSuperStar
Jan 22, 2004 03:02 PM
