Suspension & Brakes Theory, alignment, spring rates....
Shocks and height?
Old Jan 8, 2005 | 12:34 AM
lj420p's Avatar
Default Shocks and height?
Does anyone know if shocks can affect the height of a drop? I have H&R race springs, but i was wonder if i got shocks if it would make it any lower or any higher...
thanx
Old Jan 8, 2005 | 07:10 AM
CRX Lee's Avatar
Default Re: Shocks and height? (14toda)
Shocks with a normal stock spring perch location will not make our car sit any higher or lower unless there is a drastic diffenerence in the internal gas pressure. If you go from a non-gas shock to a mono-tube high pressure gas or vice versa, there might be a very minor change in your height.
Some shocks like the Koni Sports for a number of cars offer an adjustable spring perch location such that you may be able to slightly raise or lower the car a bit but you need to make sure your springs and the settings you use are compatible (not too low, not risking coil bind).
Your primary tool for setting your ride height is the spring though.
Old Jan 8, 2005 | 11:46 AM
lj420p's Avatar
Default Re: Shocks and height? (CRX Lee)
Thanks for the info, helped alot.
notsoslow
Suspension & Brakes
May 26, 2009 04:13 AM
ssoratokad
Suspension & Brakes
Aug 11, 2007 02:55 PM
Libertariat
Suspension & Brakes
Aug 31, 2006 03:17 PM
CivicHP
Suspension & Brakes
Aug 21, 2006 08:36 PM
Integra187
Mar 26, 2002 07:38 PM
