Suspension & Brakes Theory, alignment, spring rates....
need to replace cv boot for alignment??
Old Jan 16, 2005 | 07:58 AM
Joon Joon's Avatar
Default need to replace cv boot for alignment??
wats up guys.. well i'm going in for an alignment on wednesday.. i have a torn cv boot and last night i saw that i have a torn boot on my rack and pinion/gear box.. [IMG=http://www.hondaautomotiveparts.com/catimgs/13SR80_J23.gif][/IMG] #15.. should i get these affect the alignment process??? tia
Old Jan 16, 2005 | 09:40 AM
Joon Joon's Avatar
Default Re: need to replace cv boot for alignment?? (vtecenjun)
bump.. someone help me out
Old Jan 16, 2005 | 11:30 AM
Joon Joon's Avatar
bump again.. i need to know so i could get this done before my alignment..
Old Jan 16, 2005 | 02:07 PM
Joon Joon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecenjun &raquo;</TD></TR><TR><TD CLASS="quote">bump again.. i need to know so i could get this done before my alignment.. </TD></TR></TABLE>
Old Jan 16, 2005 | 05:40 PM
STperformance's Avatar
No, a torn cv boot or a rack and pinion boot will not affect your alignment. But you should still get your cv boot replaced. Have a tech check the joint for damage first. You can take of that before or after your alignment. The 2 are not related.
Old Jan 16, 2005 | 05:52 PM
Marauder's Avatar
Default Re: need to replace cv boot for alignment?? (STperformance)
Well, to replace the rack and pinion boot, you have to take off the outer tie rod. This does affect your alignment. Its would be better to have that changed before the alignment.
Most alignment shops will garauntee the alignment for a certain period, so you can change the boot later and just have the alignment checked after you fix the boot.
When you take off the outer tie rod, you can mark where the tie rod was and put it back in the same place, which may or may not affect your alignment at all. Its just safer to do the boot first.
Old Jan 16, 2005 | 07:11 PM
Joon Joon's Avatar
Default Re: need to replace cv boot for alignment?? (Marauder)
thanks guys.. i think i'mma change them out tomorrow.. i also gotta do the rear bearing cup thing on the left rear trailing arm..
Old Jan 16, 2005 | 09:22 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">
When you take off the outer tie rod, you can mark where the tie rod was and put it back in the same place, which may or may not affect your alignment at all. Its just safer to do the boot first.</TD></TR></TABLE>
I would do this now and then get the alignment done. It saves you from making two trips, and replacing the steering boot is easy. The CV boot has nothing to do with it and can be changed without changing your alignment.
horror
Jul 29, 2014 01:14 PM
Yyz
Feb 21, 2005 11:48 AM
spicoli
Jan 10, 2005 07:29 AM
kb798
13
May 27, 2004 12:55 PM
JCracer723
10
Jan 22, 2004 02:54 PM
