Suspension & Brakes Theory, alignment, spring rates....
problem!!!
Old Jan 17, 2005 | 08:45 PM
sohcondis's Avatar
Default problem!!!
i have a 2001 4dr civic and i put tein drop springs now the back looks lower wat could be the problem open to opinions the tires on the back have little camber wear could that be the problem i also got a 89 4dr civic and it got into a accident before i bought it now it pulls to the right and eats up my tire and i think the axel makes nosie plus its hard to drive in the rain would i have to change the whole front suspension or axel i duuno let me know thanks
Old Jan 17, 2005 | 09:09 PM
EK4civichatch's Avatar
Default Re: problem!!! (sedan4life)
Wait and see if the springs settle to see if your car will even out, and get an alignment to see if that stops the car from moving to either side.
Old Jan 17, 2005 | 11:33 PM
sohcondis's Avatar
Default Re: problem!!! (EK4civichatch)
thanks for the comment ill do that
Old Jan 18, 2005 | 02:37 AM
00R101's Avatar
Get thee to a mechanic to fix your noise. Axle noises rarely go away by themselves. Fixing the problem now may be cheaper than waiting.
Is there any chance that you put the switched the front and back springs when installing the lowering springs?
Old Jan 18, 2005 | 05:21 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sedan4life &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2001 4dr civic and i put tein drop springs now the back looks lower wat could be the problem open to opinions the tires on the back have little camber wear could that be the problem i also got a 89 4dr civic and it got into a accident before i bought it now it pulls to the right and eats up my tire and i think the axel makes nosie plus its hard to drive in the rain would i have to change the whole front suspension or axel i duuno let me know thanks </TD></TR></TABLE>
Damn. That post is so hard to read I dont even know where to start.
If you have accident damage, fix it before the car gets unsafe to drive on the road - it sounds like you dont know where to start, so take it to someone that does.
Old Jan 18, 2005 | 08:41 PM
sohcondis's Avatar
Default Re: problem!!! (00R101)
well theres no way u can put the front and back springs on wrong they look diff. so i dunno wat could be the problem
bjizzle07
Honda Civic (2006 - 2015)
19
Jun 9, 2008 05:47 AM
harmonator84
Suspension & Brakes
Mar 10, 2007 05:25 PM
hybrid_vtec
Suspension & Brakes
May 31, 2005 08:35 PM
92inprogress
May 19, 2005 08:41 AM
graveltravel
22
Nov 29, 2004 08:18 AM
