Inner diameter of ground control sleeve
Hi guys i had a thread saved or at least I thought I had it bookmarked of the difference between the koni gc sleeves and the stock gc sleeve. I've been searching for three days and have tried every possible wording configuration I can think of so I'm just gonna ask here. Believe me I've tried to not have it come down to this haha. What's the inner diameter of the koni compatible ground control sleeve? I have some gc coils here and I'm wondering if I should order some konis if they're compatible or just get something that I won't have to make work. I don't know how I'd mount the gc coils on the konis if they weren't compatible. Thanks for any help guys
Re: Inner diameter of ground control sleeve
Sounds good thank u sir what about the tokico sleeve? Are they they same as stock ones? Reason I ask is because I never see anyone mount then on tokicos
gc sleeves for oem shocks are the same for tokico blue/illumina. To mount non koni gc on koni shocks you just need to do this https://honda-tech.com/forums/suspension-brakes-54/not-write-up-write-up-skunk2-konis-2592526/. That is what i did on my old koni/gc setup.
gc sleeves for oem shocks are the same for tokico blue/illumina. To mount non koni gc on koni shocks you just need to do this https://honda-tech.com/forums/showthread.php?t=2592526. That is what i did on my old koni/gc setup.
Edit: nvm just saw they don't make em anymore so I'm sol, or find something similar to male em fit I guess
Nonvtak monster
Suspension & Brakes
11-26-2013 12:12 AM
Iloveyourhonda92
Suspension & Brakes
12-29-2010 10:24 PM
