Suspension & Brakes Theory, alignment, spring rates....
Eibach Sport + Koni Yellow Question(s)
Old 04-14-2014, 09:25 PM
MrOsvaldo221's Avatar
Default Eibach Sport + Koni Yellow Question(s)
I have a 96 Honda Civic that has the Eibach Sport System Kit http://www.tirerack.com/suspension/s...6&autoModClar= The rear sits a little higher and I was wondering if I purchase rear Koni shock, how much can they lower the rear by? I think they have 3 perches. http://www.tirerack.com/suspension/s...6&autoModClar=
Old 04-16-2014, 07:39 AM
Reyes's Avatar
Default Re: Eibach Sport + Koni Yellow Question(s)
That link is to a set of Bilstein dampers.
But to answer the question, yes if you position to perches differently you can adjust the right height a small amount. Most Civics need a bit more drop in the front to level out.
Old 04-16-2014, 12:50 PM
egsleepercivic's Avatar
the rears have 3 locations
upper spot = raised higher than stock about 1/2 - 3/4 inch
middle = stock
Lower = about 1/2 -3/4 lower than stock
on my integra with oem type r springs and koni yellows I set the rears on the lower perch to level it out and left the fronts on the stock(upper) perch
and for the konis hit up THMotorsports in the market place for a good price
Old 04-19-2014, 04:08 PM
think it'll be right for this amount of space? maybe it'll be too low?
Old 04-20-2014, 08:51 AM
if it was me I would try it, should get you pretty close, i don't think it will make it lower that the front. would you make the change yourself or would you have to take it to a shop?
Old 04-21-2014, 07:52 AM
shop most likely, a mechanic who is my father's friend. He installed the Eibach Sport System when I got that. I'm sure the shocks will come with directions too, about the perches. I might order them off Ebay from autoanything since they have the best price.
Old 04-21-2014, 09:38 AM
check thmotorsports in the market place, they have pretty good prices and they are a sponsor on this site
Old 04-22-2014, 02:54 PM
Will do. Thank you for your input, it's appreciated
t_c_l_6
Suspension & Brakes
03-19-2006 05:29 PM
onramp
02-19-2004 08:32 PM
integranator
01-04-2003 07:18 PM
Razor
05-07-2002 08:11 PM
Greyout
12-25-2001 11:07 PM
Quick Reply: Eibach Sport + Koni Yellow Question(s)
