Hardrace LCAs quality?
Does anyone have any experience with Hardrace LCA's? I know their bushings are good and last like OEM. But, I wanna know if their LCA's the same?
Ferio Wdm Edition
Re: Hardrace LCAs quality?
I have the 5 piece mount set amd the motor fell because of the post mount bolts. No mount was destroyed. If its the same material, then id say go for it. Truhart also uses hardrace bushings.
I have the rear lca on my 92 civic and I think they look exactly like a set of blox lca. I just hope the bushings put up with the abuse compared to the blox I had before.
Im sorry man, in thinking sway bar endlinks, my bad, i had Function 7 rear LCAs, but hard race front sway bar endlinks are good.
Sorry about that
Sorry about that
Thanks!
- DM
Steve at Heart
http://www.jhpusa.com/store/pc/viewP...&idcategory=26
Looks like for the pillowball style not sure about the standard rubber bushings.
Hardrace Rear Lower Control Arms (Pillowball) 88-95 Civic / 92-97 Delsol / 94-01 Integra - JDM Honda Parts USA
Thanks again!
- DM
I was doing some more poking around today and these Allen type screws are used in the lca's as a simple way to replace the bushings when they go bad or rather are used up and ready to be replaced. If I use loctite, do you think I'll run into a problem loosening the screws when the time comes to replace the bushings?
Thanks and again, appreciate the knowledge!
- DM
Steve at Heart
You can use blue which is low temp. If you use a red high temp loctite a propane torch applied to the bolt will allow it to come right out. Basically heating the loctite itself releases it.
snakepirates
04-16-2006 07:29 PM
