NSX Rotor on ITR 5 Lug
Hey guys just looking for some clear answers on this topic since I can't seem to find any.
I'm planning on doing a 5 lug swap on my civic and the seller threw in NA2 front and rear calipers. Now i know that if i use the stock itr rotor I will need the T23 bracket for the front and a fastbrakes rear bracket to be able to use the NA2 calipers, but if i use NA2 rotors (28mm T28) will i be able to use the calipers without the other brackets? Basically can i use the stock NA2 rotors and calipers on an itr5 lug without any modifications/complications?
I know that I will need to find a wheel to be able to clear it without rubbing.
Thanks in advance for the replies
Re: NSX Rotor on ITR 5 Lug
NSX rotors and calipers vary by year. 96 and earlier are one thing, 97 and up are another. Rotors are either 21mm or 23mm. The diameter of the later rotors are 302mm and the earlier rotors are 282mm. The pistons on the 96 and earlier are 43mm. I don't know what the later ones are. That's much bigger than the normal rear piston size because it was a mid-engine car. This would severely bias the braking to the rear on a front engine car. Just be aware of that.
The calipers are NA2
Scotty Dosent Know
Suspension & Brakes
37
08-16-2008 10:26 AM
