eg popping front end
94 eg pops when turning left or going over bumps. when it pops I can feel it under my feet. I also have a popping when letting of the gas to shift from the right front. Any ideas?
Re: eg popping front end
Turning and on bumps sounds like a balljoint, jack up the car and try shaking the wheel up and down (holding at 12 and 6). Any play will indicate either a balljoint of wheel bearing issue so you have to watch or have someone else watch as you shake the wheel. You can also shake side to side to check for tie rod play
