Suspension & Brakes Theory, alignment, spring rates....
GC coilover problem?
Old Jan 5, 2007 | 05:29 PM
sodero's Avatar
Default GC coilover problem?
so, i recently bought a set of used koni yellow's and GC coilovers off a buddy of mine. they are in good shape and everything, and i'm sure everything will work fine.. but the problem is that the allen head bolt, on one of the coilovers that tightens the adjuster ring on the sleeve is stripped... what are my options here?
and the other 3 bolts on the other one's are SUPER tight, and i don't want to strip them too... what should i do?
any ideas will help.. thanks
Old Jan 5, 2007 | 05:41 PM
b16blkhatch22's Avatar
Default Re: GC coilover problem? (sodero)
take a bigger allen wrench and try to force it in there with a hammer or something. then use some squirl ****(sea foam) lubricant and lube it up. that will prolly work
Old Jan 5, 2007 | 05:46 PM
sodero's Avatar
Default Re: GC coilover problem? (b16blkhatch22)
oddly enough thats actually the EXACT first thing i tried. it was even seafoam i used..
didn't work though. it felt like it was starting to strip again, so i stopped. the bolts are in super tight, or are siezed. thanks for the try..
the bolts aren't reverse threaded are they????
i doubt it, but ya never know.
Old Jan 5, 2007 | 05:53 PM
did you let the squirl **** sit for awhile and kinda hit the screw abit so the **** will get down into the base of it?
Old Jan 6, 2007 | 04:39 PM
slammed_93_hatch's Avatar
id suggest drilling them out. and don't ever tighten them down that tight. It doesn't need to be tight at all. but its a safety precaution.
Old Jan 6, 2007 | 07:05 PM
sodero's Avatar
Default Re: GC coilover problem? (slammed_93_hatch)
thanks guy's. it looks like i'm just gonna have to drill them out.. unfortunatly.
and it wasn't me who tightened them in the first place... i have no idea who did, but i think i hate them now.
Old Jan 7, 2007 | 06:32 PM
89POS's Avatar
the allen key thing is a lil time consuming.googluck drilling and retapping.
Old Jan 7, 2007 | 06:45 PM
chrisw85's Avatar
what size allen are you using? Its a 3/16" and not metric as fas as I know.
JDMsalinger
Suspension & Brakes
Aug 11, 2013 04:37 PM
fms1day
Suspension & Brakes
Jun 24, 2005 07:20 AM
fms1day
Jun 23, 2005 02:50 PM
Luchini
Dec 4, 2004 01:02 AM
5spdIntegra
Nov 28, 2004 06:11 PM
