Suspension & Brakes Theory, alignment, spring rates....
Should I wait for an alignment?
Old Jan 2, 2007 | 10:47 AM
ES2's Avatar
ES2
Default Should I wait for an alignment?
I am getting new dampers installed this Wednesday and was wondering if I should wait a couple of days for the suspension to settle to get an alignment or can I get one right after the install?
Old Jan 2, 2007 | 12:53 PM
TunerN00b's Avatar
Default Re: Should I wait for an alignment? (ES2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ES2 &raquo;</TD></TR><TR><TD CLASS="quote">I am getting new dampers installed this Wednesday and was wondering if I should wait a couple of days for the suspension to settle to get an alignment or can I get one right after the install?</TD></TR></TABLE>
Your suspension should not "settle", unless you have springs that can be bent into a different shape purely be the weight of the car. In which case, it won't matter when you align it, because the alignment will continue to change as the car continues to get lower and lower as the springs bend.
If you correctly reset the bushings for a changed ride height, the car shouldn't settle. Just chanigng shocks shouldn't change ride height, unless the shocks internal pressure are both holding the car up higher than springs alone would, and will change over time, which they shouldn't.
DRKSol
10
Jun 22, 2007 02:18 PM
UNLTD
Jan 17, 2007 04:03 PM
dudeomega2000
Suspension & Brakes
Aug 9, 2006 08:40 AM
Zulu888
May 12, 2003 02:23 PM
216.226.142.95:27016
May 1, 2003 08:22 AM
