Suspension & Brakes Theory, alignment, spring rates....
Trailing Arm Bent? or Something Else?
Old Jan 3, 2007 | 05:38 PM
A.E Motoring's Avatar
Default Trailing Arm Bent? or Something Else?
well i was taking my camber kit off from the rear and wanted to put the stock arms back in, (which i did put back in) but thing is the camber was fine on the driver side but on the passenger, it was cambered into the fender ALOT with the rear suspension raised up, the bottom of the tire was sticking out alot, the top of the tire was pushed in at the top, could it be the trailing arm is bent? or just needs to be aligned some how? the adjustments on the camber kit were offset before i took it off
Driver Side - was short (---)
Passenger - Lengthend to make positive camber (--------)
not sure wat kinda camber kit it is, but its the kind that u adjust by undoing a nut and unscrewing to make postive or negative camber
lethal_si
Suspension & Brakes
11
Aug 10, 2013 12:58 PM
alexm
Suspension & Brakes
16
Apr 27, 2009 11:52 PM
garyc17
Suspension & Brakes
Apr 13, 2008 08:39 AM
Mike1995HondaPrelude
Aug 15, 2007 06:38 AM
