Suspension & Brakes Theory, alignment, spring rates....
what does caster do??
Old Jan 10, 2007 | 06:09 PM
89POS's Avatar
Default what does caster do??
96 acc.
got a print out of my alignment as it sits and my caster is off on the right side only.what does it do??
and i know i need the shims to fix it.(can u use washers??)
Old Jan 10, 2007 | 07:29 PM
HondaF1Fanatic's Avatar
Default Re: what does caster do?? (89POS)
http://en.wikipedia.org/wiki/Caster_angle
Read Up
Jon
Old Jan 10, 2007 | 08:38 PM
suspendedHatch's Avatar
Caster means that your front wheel is shifted forward or rearward in the wheel well. Positive is forward, negative rearward. It isn't adjustable on Hondas/Acuras. It's caused by suspension damage from a severe impact like a curb or collision with an object. The only worthwhile way to repair it is to replace the bent suspension component.
Old Jan 10, 2007 | 08:49 PM
slammed_93_hatch's Avatar
Default Re: what does caster do?? (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">. It isn't adjustable on Hondas/Acuras..</TD></TR></TABLE>
on the 94-01 integras, and 92-00 civics you can swap the front UCA and that gets you some good caster
prelude_93vtec
Mar 5, 2008 09:31 AM
r0n3l
Apr 23, 2007 04:14 PM
TurboedDelSol
Oct 17, 2005 09:04 PM
EK k kay
22
Aug 31, 2004 07:55 PM
warmboi504
Acura TSX
Aug 25, 2004 07:12 PM
