Suspension & Brakes Theory, alignment, spring rates....
quick question on assembly!!
Old May 3, 2007 | 03:59 PM
fwdftw's Avatar
Default quick question on assembly!!
So i installed my ground controls today.. followed all the instructions used the correct rubber gromets for the shock ive installed ground controls like 5 times now. lol but when i got done . i had noticed a noise.. so i poped the cover off to notice.. the shock was purtruding out of the top hat by about 3 inches. now could this bc bc i didnt install this ring back.. for the bump stop im pretty sure i did.. im just tryin to figure it out im a take it all off tommorow and look.. just curious
thanks alot!
Old May 3, 2007 | 04:25 PM
Tyson's Avatar
Default Re: quick question on assembly!! (FwdFtw)
what the hell? what are you talking about "little ring right before the bumpstop"?? there should be nothing below the bumpstop.
you obviously messed up the bumpstop plate. its a thick washer that has a goldish color and is shaped to fit the taper on the shock rod.
redo your whole suspension. immediately.
Old May 3, 2007 | 04:52 PM
fwdftw's Avatar
yes #14 im sorry i meant after
Old May 3, 2007 | 04:53 PM
fwdftw's Avatar
i forgot to put that back on.. so its not a good idea to drive to work? just wait and redo it tommorow i reckon.. ill get a ride to work.
Thanks!
Old May 3, 2007 | 04:59 PM
Tyson's Avatar
Default Re: (FwdFtw)
not safe.
at least it should be easier to do the 2nd time around.
Old May 3, 2007 | 05:03 PM
fwdftw's Avatar
thanks a ton! ill be sure to do that ASAP tommorow.. is the car safe.. like on thr ground not moving? there oem shocks.. so im not worried about them blowing theyll be AGXS on the way soon
Old May 3, 2007 | 05:06 PM
Tyson's Avatar
itll be fine sitting there.
just dont drive on it. it will push the shock completely past the top mount without the bumpstop plate (#14).
Old May 3, 2007 | 05:18 PM
fwdftw's Avatar
thank ya much why is it so bad thou just curious what could happen
Old May 3, 2007 | 05:36 PM
Tyson's Avatar
push a hole through your hood.
Old May 3, 2007 | 05:38 PM
fwdftw's Avatar
there in the back heh
Old May 5, 2007 | 06:53 PM
fwdftw's Avatar
got it all apart and etc.. noticed that the bushing UNDER the top hat was missing ordered a bushing kit at work and will install 2moro! hah thanks
fwdftw
May 3, 2007 09:59 PM
budget
Suspension & Brakes
Jul 8, 2006 10:50 AM
tvrsir
Suspension & Brakes
Oct 24, 2005 12:46 PM
Civicman86
Suspension & Brakes
May 6, 2005 04:33 PM
ZColeon
Feb 17, 2003 08:05 AM
