Suspension & Brakes Theory, alignment, spring rates....
spring preload
Old May 3, 2007 | 09:49 PM
m1northreat's Avatar
Default spring preload
this may sound dumb but im not sure what this is and hows its done. anyone care to help out. i tryd the search and didnt find anything on "spring preload"
Jairo j
Old May 3, 2007 | 11:27 PM
tyre_meets_mud's Avatar
Basically preload is what happens when the spring in an adjustable coilover is compressed from changing the height using the lower spring perch. For more details, you might want to search for "preload" in the archives.
Old May 4, 2007 | 09:46 AM
Tyson's Avatar
Default Re: spring preload (m1northreat)
ignore preload.
really. its nothing.
Old May 4, 2007 | 03:42 PM
shoryuuu's Avatar
preload is compressing your springs.
For example, TEIN SS and sleeves coilovers use preload to adjust the height of the car, because they only have 1 perch for each coilover/shock. For TEIN FLEX, each coilover have 2 perches, so you can adjust the height indepently without touching the preloads. I hope this help.
Old May 4, 2007 | 08:54 PM
well i read that basically preload is what u do for the shock so that if the suspension hangs freely with out the tire touching the ground the spring wont have any play. so what u are sayin with the 2 perches u can make it so theres no play and less strain on the spring at the same time as lowering the car. im gettin it now. thanx guys.reason i ask is cause my buddy club racing specs are on there way to my house
jairo j
Old May 4, 2007 | 08:58 PM
spoon_ek9's Avatar
Default Re: (m1northreat)
basically, preload is to set where do you want your shock piston at when the car is on the ground, as long as u got good travel, then preload is not as important.
Old May 5, 2007 | 01:01 PM
shoryuuu's Avatar
I used to have BUDDY CLUB N+ SPEC coilovers on my EG, it's bascially the same as the one that yu ordered. But yeah for the preload, just let the spring touches the top and perch, dont compress it. Go to clubRSX.com and go to the suspension section, look around, there a thread that will show you what to do and how to install and set the preload right!!!
1320fuel.com
Jan 21, 2014 03:04 PM
eg6_danny
Suspension & Brakes
Jan 29, 2011 11:16 PM
JDM Factor
Aug 6, 2006 04:12 PM
donz
Jun 27, 2004 11:45 AM
euclid
Feb 13, 2004 08:50 PM
