Suspension & Brakes Theory, alignment, spring rates....
Ground control install
Old Dec 26, 2008 | 11:58 AM
yaryar's Avatar
Default Ground control install
So im installing GCs on my 05 civic. Im on stock shocks and just slipped them on. When i turn left the front left spring will pop. Its only when i turn when i drive straight it is fine has anybody had this problem? Any help would be appreciated
Old Dec 26, 2008 | 12:21 PM
00si_guy's Avatar
Default Re: Ground control install
my front left pops sometimes when i take off or turn too. i think it is just because of the pressure but im not sure. i did however tighten the strut back up and it stopped the problem when turning, still does it when i take off though.
Old Dec 26, 2008 | 07:33 PM
yaryar's Avatar
bump for help
Old Dec 29, 2008 | 07:20 PM
KillaSIPP's Avatar
I dont know if its just yr/make/model problem but I had a set on my 94 and it never made any noises, you might want to double check your install maybe you forgot to center the perch on the strut and lock it in with the allen screws supplied in the kit
Old Dec 31, 2008 | 06:41 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It may have to do with the Mac strut upper mounts used on those cars. I know there was a TSB about early 7th gen Civics and RSX's doing that even with stock springs, but I'm not sure if that would be the case on a 2005 model.
Old Dec 31, 2008 | 09:30 AM
myprotege's Avatar
I have also heard this. It may also be the position that your spring is in. Next time you have the car in the air, try turning your spring 180% and see if this helps. May be useless but I've heard it works.
Old Dec 31, 2008 | 02:46 PM
yaryar's Avatar
hmm ok, i think it might be that its not lined up entirely right i got one of my buddies comin over in a bit and i will let him know your feedback, it sucks not being able to drive my car though
Old Dec 31, 2008 | 04:37 PM
yaryar's Avatar
so we were able to diagnose it the springsare sliding and when they turnthey slide and then pop back in to place. Im gonna call ground control tomorrow.
Old Dec 31, 2008 | 05:39 PM
Honda Rules's Avatar
did you forget to take off the top mount bearing from the stock spring perch?
their is a bearing underneath that, take it off and put it in between the top mount and the gold plate and the popping noise will go away
Old Jan 1, 2009 | 08:33 AM
yaryar's Avatar
ya we didnt install it the first time, and both sides were popping then we put them on and the right side stopped but left side still popped....
Old Jan 1, 2009 | 07:36 PM
just lift the car and make sure the bearing sits properly when lowering back to the ground, i have a 03 em2 with gc's i had the same problem at first
Old Jan 2, 2009 | 02:37 AM
92civiceg9gsr's Avatar
The spring tension may not be enough to turn the bearing plate. ALOT of these model hondas make the pop. On my buddies em2 I put spring rubbers on the top of the springs and they still move but you dont hear a pop.
bdubnyc
23
Oct 14, 2008 06:06 PM
TylerC161
Mar 28, 2007 06:17 PM
dre000
May 10, 2003 10:59 PM
lsvtec101
Mar 11, 2003 10:07 AM
TeamTooQuick
Mar 22, 2002 07:10 AM
