ALIGNMENT
so i recently got an alignment because i added positive camber to one of my rear wheels and heres the result
FRONT
toe -.01 .08
camber -4.9 -3.o
REAR
toe -.12 .15
camber -4.9 -4.4
SO HERES THE DILEMA
my rear left toe was closer to zero (-.02) and now it said he moved it. but the guy did not even touch that side because he said "the adjuster is maxed out" but isnt negative toe "toe out" and the adjustr was maxxxed out but toward the outside.
now on the rear right he did ajust the toe. he moved it more to the outside (there was room on this side) and it got closer to zero. meaning he added negative toe on that side. so why didnt he move the Rear Left adjuster to the inside to add more positive toe which it needed it?
i kinda told him but he just bombarderd me with a shhitload of bs that negative was to the right side of the car and positive to the left WTF isnt the middle of the car the axis? it was firestone btw it was lifetime alignment
patrickgsr pls chime in
FRONT
toe -.01 .08
camber -4.9 -3.o
REAR
toe -.12 .15
camber -4.9 -4.4
SO HERES THE DILEMA
Why is both driver side wheels toe'd out and pass toe'd in?
Did you ask the guy that?
EDIT- I missed that firestone did it, I still want to know why you have -1.9 degrees of cross camber in the front?
holy crap that is quite possibly the worst "after" alignment readings I have EVER seen. Your car is going to be driving down the road sideways like that, chewing the tires with every single tire rotation.
Since you have the lifetime alignment I think you definitely need to take it to a different Firestone location and get them to fix it up.
so i wont need a rear left toe kit? cos the readings say i have negative toe (toe out right?) and the adjuster is also maxxed out toward the left (toe out) position.
either the mechanic or i are complete noobs he said i need a toe kit
i dont have camber kits so its not possible that its messed up
im tucking half a 195 50 15
he got his axis' mixed up huh! i knew i was right he said that the neg/pos switches with left tire or right tire i didnt want to keep arguing with him since i was sick as fuxx and waited for hella long, i dont know if i should return cos thats the only firestone i know that has the ground rack
Take to another shop, and have the re-do it, and come back with the numbers.
Something is deffinetly going on on the passanger side, that amount is not normal.
I can honestly say I would have flipped if that was my car, deffinetly complain.
i will be calling around firestones tomorow to find one with a ground rack.
so on the RL it needs to be toed in right? moving the adjuster toward the middle of the car right?
Yes, well I think so. If I am wrong someone correct me.
In either situation you need to figure out why one side is toe'd out and the other toe'd in. And also why there is such much cross camber in front.
well i just found this and i guess im half wrong.
the rear left needs to be toed out more but its maxed out according to this chart. but
the rear right needs to be toed in (but the guy that aligned it pushed the rear right out
and according to this chart it should have made the toe more positve) but according to
firestone alignment chart it made it closer to zero WTF
well it is wrong according to you guys and the link above.
now that i remember the dudes at the alignment show used like one of these
to hold the ****ing sensor in the rear left i shoulda know something was up FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
Yea, go to a different one.
I know which firestone I will never go back to. Due to their inability to set the toe where I wanted it set. After the tech was told multiple times, and it was written down.
it depends on the machine. all modern machines refer to toe out as -
there are a lot of noobs on the corvette forum too, i also post there
that -5 camber is a problem. your car is so low you have no suspension
and i have 10k and 6k rates so i rarely bottom out. and the machine looked brand new. that firestone is new also. i thinks it was that faulty sensor and the tech that messed up ill hit up another firestone tomorrow and ill update the numbers here
Every resource I've ever read refers to toe out as negative and toe in as positive. So no I would not go by those graphics posted above.
I guess the real question is: How does it actually drive with those numbers? Surely the steering wheel can't be straight when driving straight ahead with numbers like that, right?
right. and it pulls to the right.
not as bad as some other cars i have driven.
but performance wise. with the wheel setup i dont think ill ever know the real limits since the wheels are heavy as *** and i really dont autox, sure its fun on freeway on/off ramps but i am responsible driver and dont push it.
UPDATE
i called several firestones and told them what happend and they said to call the one i got the aligment from and that i should even be given gas money.
so i called and they said to go back but they didnt say sorry or anything punks. i dont have time till next weekend. ill refrain from driving except school.
UPDATE
FUUUUUUUUUUUUUUUU
so i called them and the first time they said to hold on and that they would call me back,
2 hours passed and nothing so i call them back and saqid wtf going on and i need to get my **** fixed and they said they were gonna call me back again! my dumb *** didnt go ****** on them and clicked and now the day is over and NOTHING
is there any way i can seek legal action? i have the print outs withe the before and after and how they made it worse
me.
