Suspension & Brakes Theory, alignment, spring rates....
Spacers ?
Old Feb 14, 2011 | 07:16 PM
DUKE LADUKE's Avatar
Default Spacers ?
Probably a stupid question but I was wondering if you could use a small spacer with oem wheel studs . Like if you do a 5-10 mm would you still need to do longer studs ? . I wanna bring the rear wheels out more and fronts a tad bit . Just new at this ..
Thanks
Old Feb 14, 2011 | 08:23 PM
98civdx's Avatar
Master Detailer
Default Re: Spacers ?
5 is the absolue biggest.
10 would be to much..
If you can get 6-7 turns on the lugnuts, your ok....
I have 3mm on my car.
Old Feb 14, 2011 | 08:27 PM
k thank you ! . Just curious if I do go with spacers what I will need to change up .
Old Feb 14, 2011 | 08:32 PM
98civdx's Avatar
Master Detailer
How large?
Extended studs would be required.
You could do a TL wheel stud, they are longer than the stock studs.
Old Feb 14, 2011 | 08:36 PM
I was either gonna keep oem wheels and add spacers to the hx's . Or just get another set of wheels . I wana get the back wheels pushed out more . Just looks to tucked in .
Old Feb 14, 2011 | 08:42 PM
98civdx's Avatar
Master Detailer
I know how you feel, mine are the same way. I need spacers just for the rear to clear the trailing arms.
there are spacers with build in studs, however they tend to be 10-15mm+ in size, and are kind of expensive.
Old Feb 14, 2011 | 08:47 PM
alphalanos's Avatar
I have Ichiba 15mm, I think they were like 120/pair.
Old Feb 14, 2011 | 09:02 PM
hmm thats not to badd
Old Feb 14, 2011 | 09:10 PM
98civdx's Avatar
Master Detailer
I was quoted 225 shipped for ichiba 15mm with studs.
Old Feb 14, 2011 | 09:19 PM
wannaBjdmca6's Avatar
^too much.
look in the marketplace i got my 20mm ones for 115 shipped to my door brand new i 4g0t the company name
Old Feb 14, 2011 | 09:41 PM
98civdx's Avatar
Master Detailer
That's was for 4 lol
That would be your best bet, if your only looking for 2.
Old Feb 15, 2011 | 03:44 PM
How much do you think would bring it to make it look bettter ?
Old Feb 15, 2011 | 03:58 PM
98civdx's Avatar
Master Detailer
Post a pic, what offset is the wheels?
Mine are +55.
Old Feb 15, 2011 | 04:39 PM
2k.civic.si's Avatar
H&R makes hubcentric wheels spacers....i used them on the back of my scion xb to get the wheels to clear...definetly top quality
Old Feb 15, 2011 | 05:45 PM
Mine are +45. They are hx wheels
Old Feb 15, 2011 | 09:55 PM
98civdx's Avatar
Master Detailer
Oh ok.
If you have some washers or something. You can cut it out to fit the hub, put it on, and then put the wheel over it. Measure and would give you an idea of how large you will need to get it where you would like it.
I just thought of that now lol.
Old Feb 15, 2011 | 09:58 PM
*JDM*Ej8*'s Avatar
I had a problem runnign my hx wheels on my 97 ex and had to buy wheel spacers. I have them for sale set of 2 40 shipped they are 7mm definately safe on stock studs ran mine for a year track and street
Old Feb 16, 2011 | 10:49 AM
how did they look with spacers ? noticable with 7mm ?
Old Feb 16, 2011 | 10:59 AM
alphalanos's Avatar
this is 15mm on my 96 sedan with 15x7 +40 rotas. Just to give you an idea. front has spacers. rear is stock.
Old Feb 16, 2011 | 11:08 AM
ahh yea thanks for the pic . Yea I gotta go bigger then 7mm lol
Kris05TSX
Sep 29, 2013 09:44 AM
alscrx
12
Jul 28, 2008 02:47 PM
bowflex21
Jan 27, 2007 01:34 AM
1 2 NV
Jan 24, 2003 04:49 PM
