Suspension & Brakes Theory, alignment, spring rates....
Alignment issue
Old Feb 11, 2011 | 08:50 AM
APAem1's Avatar
Default Alignment issue
about a week ago i installed a set of coilovers on my car. I let it settle for a day or two then i went to get an alignment at the shop. However after a week of the alignment i noticed my car height went down a little bit ( not significantly) . My question is that, Do I need to get another alignment? thanks in advance
Old Feb 11, 2011 | 09:15 AM
96hb's Avatar
Default Re: Alignment issue
What coilovers do you have? I don't think they should be settling like that.
Old Feb 11, 2011 | 10:22 AM
98civdx's Avatar
Master Detailer
How much is it?
Idealy whenever the ride height changes you need to get it re-done.
Car goes down, toe goes out.
Old Feb 11, 2011 | 11:25 AM
TunerN00b's Avatar
If the car "settled", it sounds like the bushing were not correctly clocked. Neither the springs nor shocks should ever settle on their own.
Pick a final ride height, clock the bushings, then get it aligned.
Old Feb 11, 2011 | 12:02 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If you have rubber bushings, this is probably what has happened. The "settling" that you notice is actually the bushings tearing, or at least the inner metal sleeve slipping around the bolt to equalize itself with its current ride height.
Old Feb 11, 2011 | 02:43 PM
APAem1's Avatar
The drop is minimal no more than even half a finger. Before i had a whole finger gap but now the gap is still there but just tighter fit. I bought a set of progress coilover advertised on HT. How much height drop will result toe change. Id say the change was no more than 0.15 inches. Thanks
Old Feb 11, 2011 | 03:02 PM
2kdb8's Avatar
that little of change i'd doubt would change your settings enough to cause any issues. when i used to work at toyota i'd check my alignment like every month for the hell of it. was slow at work one day so i lowered my car like another 1/2 inch and rechecked my alignment and everything was still in the green. changed a little but nothing that i had to go back and adjust it. so 0.15 of an inch i wouldnt worry too much but it never hurts to check.
jxhxb
Suspension & Brakes
Jan 9, 2009 10:51 AM
ek4d00r
Suspension & Brakes
May 17, 2005 03:40 PM
96hb
Mar 24, 2004 06:32 PM
wuclan
Feb 24, 2004 12:07 PM
EL'ation
Sep 28, 2002 01:11 PM
