Bad Tire wear
Bad Tire wear
So i just got my car like 6 months ago and i have very bad camber wear.. And i have searched the forums and what not found a topic you dont need camber kit, and then there is people saying you do??? Looking to fix this fast it has ate all my tires up..
I drive 99 civic si that has been lowered and no i don't know how far i bought the car that way..
Re: Bad Tire wear
So it just needs a aligned? All my tires are that way the front is worse then the back, but the back is also wearing on inside too.
Re: Bad Tire wear
And i don't think that the middle of tire has been wearing that much, i think first pic i posted made it look that way..
Here is another pic of the tire.
Re: Bad Tire wear
What kind of car? They don't really do front end alignments anymore, it's always four wheel. And yes, any adjustment to the ride height always affects the toe, and ultra low profile tires are especially sensitive to it. I can see the scalloping in your first picture.
Re: Bad Tire wear
And i will call see about getting it aligned this week, i need to before i blow a tire. Hopefully they dont charge a arm and a leg.
Ek Forever y0!
Re: Bad Tire wear
Adjustable camber is just nice to have so you can add camber or even the camber from side to side. Some camber is always a plus, once you get over 2* camber you can really tell a difference in handling.
And that's definitely not camber wear. Looks a lot like your tires were over inflated more than anything else.
Re: Bad Tire wear
If you zoom in on the first pic that the op put up you can see the "scalloping" that you get from toe. I have seen plenty of tires just like that over the years from people who thought they could just drop the car and not align... Including myself in my younger days.
Re: Bad Tire wear
Similar thing was happening to me.
Got 2 new tires, left the rears alone but got a 4-wheel alignment. The rears stayed okay for 6 months, then blew out on me. Got 2 more new ones at the time, and had zero issues after that.
Alignment is everything. That was LITERALLY all I changed.
Re: Bad Tire wear
Well I know for sure my tires are not rubbing something on inside that much I would hear it. And I have another question if I get a alignment will it push the top of my tire into the fender cause my car is tucking the tires alittle. ?
Re: Bad Tire wear
The Grumpiest
Re: Bad Tire wear
You don't have a choice so trying to analyze it will make no difference. Get the alignment. If you think the sidewall will contact the fender then raise the ride height then get the alignment.
Understeer
Suspension & Brakes
06-29-2005 05:09 AM
Kyles ej1
01-08-2005 04:07 PM
