weird problem with my brake
I just did a 4x114 conversion on my civic and i can get a hard pedal,
things i have change
-complete 96 itr brake conversion
-accord v6 front caliper with 92+ vtec lude 11.1 rotor
-booster/master from a ITR
-stock prop valve for now, i have a 40/40 waiting.
so the prob is, all my 4 calipers are perfectly bleeded but i have no pedal and nothing is leaking.
got any ideas what it can be?
the master isnt good?
thanks
thanks
MM Gruppe B
Re: weird problem with my brake
MM Gruppe B
If the MC had been sitting around empty/dry for a while the seals were most likely already bad before you even bolted it up.
Two things that are never worth chancing used/rebuilt, unless you know the complete history, are water pumps and master cylinders.
vsi1600
10
02-08-2010 02:10 AM
