Suspension & Brakes Theory, alignment, spring rates....
SCRAPPING AND RUBBING QUESTION
Old 07-19-2012, 06:20 PM
bmbf YERD's Avatar
Default SCRAPPING AND RUBBING QUESTION
i just ordered a set of ground control / koni setup coilovers. i got my spring rates set at circuit / street driving. none the less i have a set of of 16 inch slips sitting downstairs. the car is sitting stock as of now. i bent the taps inside on the rear, flattened them. im wondering if im gunna have to worry about the tires hitting the wheel housings when i turn ? what can i do to prevent this or do i have to evenm worry ?
Old 07-19-2012, 06:37 PM
bmbf YERD's Avatar
Default Re: SCRAPPING AND RUBBING QUESTION
i have some free time now to use the sawzall so someone please reply id really appreciate it
thankss
Old 07-19-2012, 07:00 PM
mikekh10a's Avatar
how low are you trying to go
Old 07-20-2012, 03:10 AM
The Grumpiest
grumblemarc's Avatar
Lessee.
You you don't mention the spring rates, how low you are trying to get or your tire and wheel specs and we're supposed to just figure out your problem?
This
"i got my spring rates set at circuit / street driving"
doesn't mean anything. We need numbers. Example; 450 front 350 rear.
And this
"16 inch slips"
is incomplete information.
Old 07-20-2012, 03:34 PM
MonkeyMagic's Avatar
^ nailed it
even then, we might be off op. op, just wait until your suspension gets here and test it out in the driveway.
Old 07-20-2012, 04:47 PM
bnetkillzone's Avatar
What is your suspension and wheel setup? Why is this info not given, it's pretty important. Actually all the info we need.
Old 07-22-2012, 08:23 AM
spAdam's Avatar
thankss
Old 07-22-2012, 12:27 PM
bmbf YERD's Avatar
im gunna get 16 in slips and i think 7.5 or 7 wide. i wanna go as low as possible to b honest. the spring ratest are i believe 350 front 380 rear if im correct. sorry about not giving the info lol. and i also neeed to know what size tires i should get. that would help asweell. i work at mavis discount tire, althgouh when it comes to all this stuff and mods you guys are the pros ahha. i want the side walls to b in the 40 or 45 range. ( of the width of the tire ) thanks for thre help guys i really appreciate it sorry about the lack of info aha
also. i read the , you dont need camber kits thread. what i got out of it is that on my car a i might have a problem with the rear upper a arm,... i plan on aligning the car as soon aseverything is installed, but i really dont know what do in tat matter. being said with the 16 inch rims, how low should i go? should i take off the front fender linners? and should i get a camber kit or just have my tow adjusted.?? thanksfor all the hellp guys
Old 07-24-2012, 10:24 PM
bmbf YERD's Avatar
so just adjust toe im guessing? how about a little help with tire sizing. i was thinking 205 45 16 .. some input would be appreaciated
Old 07-25-2012, 02:35 AM
Ek Forever y0!
Libertariat's Avatar
205/45/16 is the correct size tire for you. And 350/380 is really soft for "as low as possible."
My car is by no means slammed, on 350/350 and it's WAY too soft for daily driving at the ride height I've got. The suspension travel is honestly too much to make the car comfortable to daily drive. You should really have 450-550 front rates if you're going to be slamming it.
Old 07-30-2012, 05:56 PM
bmbf YERD's Avatar
GREAT TO HERE! im not to possotive on the springs rates but i know its in the high threes. what im mostly worried about is the camber, and if im going to hit the strut..also if 7.0 or 7.5 is to wide of a rim . thanks for the advice. anyone have some info on my questons?? help is much appreciated . i need to buy wheels and tires asap. im just not trying to drag myself into a mess. id rather kno everything before i puill the triigger. should i grab rear camber kits? front ? none at all . ???
Old 07-30-2012, 06:02 PM
bmbf YERD's Avatar
dont know to ,uch about offset either. i wanna get 16x7 slipstreams, but dont know what offset i should get.
Liquidgsr
Suspension & Brakes
10-01-2010 04:28 AM
SteveoBA8
05-11-2010 02:07 PM
sleepingEg8
11-04-2006 09:07 PM
Lil Corb
Suspension & Brakes
02-28-2006 09:48 AM
PrinceAli132
07-19-2004 06:17 PM
Quick Reply: SCRAPPING AND RUBBING QUESTION
