Suspension & Brakes Theory, alignment, spring rates....
Cursed with rare problems
Old Feb 6, 2007 | 12:12 AM
faSHOwidIT's Avatar
Default Cursed with rare problems
Last night i did a third gear pull and the car started to vibrate crazy from passenger side along with pulling to the right hard as hell. Cousin had the same problem due to axle, so i changed the pass. side axle. Still pulls hard to the right and vibrates crazy like as if something is loose. It all started to happen eversince i lowered my car. Keep in mind this is a 430hp motor. What the hell is going on? I'll raise the car back up tomarrow see if it still does it. keep me posted with ideas please!
Old Feb 6, 2007 | 06:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Could be the driver side axle.
Old Feb 6, 2007 | 07:20 AM
b18LS's Avatar
Default Re: (PatrickGSR94)
, yeah do both axles with that kind of power being produced. You'll go through them. check mounts as well. Hey man, good stuff on getting married. My wife and I are three years and havent looked back. Marriage kicks ***, its the kid thing on my mind now
Old Feb 6, 2007 | 09:15 AM
02 accord's Avatar
Default Re: Cursed with rare problems (faSHOwidIT)
Did you get an alignment after lowering?
Old Feb 6, 2007 | 10:05 AM
FalkenSiR's Avatar
Default Re: Cursed with rare problems (02 accord)
if it pulls to the right, it's the left axle
if it pulls to the left, it's the right axle
Old Feb 6, 2007 | 01:18 PM
faSHOwidIT's Avatar
Default Re: Cursed with rare problems (FalkenSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FalkenSiR &raquo;</TD></TR><TR><TD CLASS="quote">if it pulls to the right, it's the left axle
</TD></TR></TABLE> hm...vibration noise was coming from passenger side, but i'll get a new driver side anyways. so most likely it's axle? also it's not a normal pull like as if alignment is off, it's a hard pull like someone is forcing the steering wheel.
Old Feb 6, 2007 | 05:16 PM
faSHOwidIT's Avatar
someone out there has to have an answer
Old Feb 6, 2007 | 09:16 PM
muhaMan's Avatar
i have the same problem except my car has a whopping 102 hp.. my car is lowered also and once i reach like 65 it starts to vibrate really bad
Old Feb 6, 2007 | 11:22 PM
faSHOwidIT's Avatar
Default Re: (muhaMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muhaMan &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem except my car has a whopping 102 hp.. my car is lowered also and once i reach like 65 it starts to vibrate really bad</TD></TR></TABLE> but mine isn't like that. it doesn't wait till it hits a certain speed. Once my car start to spool hard in a gear i get traction on, that's when it does it.
Old Feb 7, 2007 | 11:52 AM
h22a4lude's Avatar
my car has been fairly low for quite some time now, my car shook pretty good whenever i took a left turn, i replaced both axles but that didnt change anything so i looked at both wheel bearings and the right one was shot, fixed it and it handled fine.
so take a look at the left wheel bearing if your out of options
Old Feb 7, 2007 | 12:06 PM
faSHOwidIT's Avatar
Default Re: (h22a4lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a4lude &raquo;</TD></TR><TR><TD CLASS="quote">my car has been fairly low for quite some time now, my car shook pretty good whenever i took a left turn, i replaced both axles but that didnt change anything so i looked at both wheel bearings and the right one was shot, fixed it and it handled fine.
so take a look at the left wheel bearing if your out of options</TD></TR></TABLE> i guess i'm going to have to learn from the hard way, just go down the check list and replace everything with brand new stuff.
Old Feb 12, 2007 | 09:39 PM
faSHOwidIT's Avatar
Default Re: (faSHOwidIT)
changed both axles, got an alignment, problem still here!
Old Feb 12, 2007 | 10:58 PM
slammed_93_hatch's Avatar
look at your tie rod ends, the ball joints, and your wheel bearing. Get a helms or a FSM and it will tell you how to check for all of that stuff.
kraquepype
30
May 10, 2018 08:48 PM
DC2SIR-G
Feb 26, 2006 06:13 PM
BigBoulda
Jan 25, 2006 08:13 AM
.M.
Sep 14, 2004 10:06 PM
drjondurst
55
Feb 13, 2003 09:38 AM
