Suspension & Brakes Theory, alignment, spring rates....
Suspension Drivability
Old Jan 25, 2007 | 05:20 PM
brad98_teg's Avatar
Default Suspension Drivability
As of now I'm a novice when it comes to suspension so bare with me here. I have a 98 Integra LS with a drag turbo kit at 14psi. My car right now looks like a 4 wheeler with a snail on it and I was thinking about dropping it an inch or two to make the car flow a little better. I've always been a bit scared to mess with anything suspension wise because I want to retain driving comfort as much as possible. My question is what springs or coilover kits are around so that I can retain good drivability while still dropping it an inch or two. Let me know of you experiences good or bad of any kits you've bought.
thanks for the info.
Old Jan 25, 2007 | 06:04 PM
blakh's Avatar
Default Re: Suspension Drivability (brad98_teg)
i know H&R makes lowering springs that are supposed to ribe about the same as stock but preform alittle better i think they are called OE springs, so does eibach. there are a few other companies that makes some like that. any time you are lowering ur car on stock shock it can cause exess stress on them so u might want check some out.
Old Jan 25, 2007 | 06:08 PM
office888's Avatar
Koni makes SUPERB shocks. I highly advise the Koni Yellows, as Koni has been in the shocks business since 1932. They know their stuff. Yellows have adjustable rebound/dampening as well.
From there on, choose your coil. I advise a Neuspeed Sport spring for your application. I hear Tein S.Techs aren't too bad either.
Just an FYI, I'd highly advise ditching the OEM shocks. They're not designed for lowered automobiles.
Old Jan 25, 2007 | 06:41 PM
blakh's Avatar
Default Re: Suspension Drivability (office888)
i agree with you except i like the bilstein non adjustables, the reason for this is even though koni yellows are a great shock i have noticed that one can be set to hard and another set half way and they are the same, i amnt saying they dont adjust correctly, turning them soft makes them softer and turning them hard makes them harder, but i had 2 cars with them and to get them all the same or close to the same on a dyno they were all adjusted differntly. for street driving thats no biggie. but i prefer a shock that is set at a good setting that you cant ruin because i tend to fidget and make things worse not better! my new project will be running bilstein S shocks and H&R race springs, but my ride will be STIFF.. btw i have heard nothing but good things about the tien s techs
Old Jan 25, 2007 | 07:04 PM
brad98_teg's Avatar
thanks for all of the responses. Any of you know of any good sites to order them from?
Old Jan 25, 2007 | 07:10 PM
blakh's Avatar
Default Re: (brad98_teg)
check the forum for deals.
grndb8
Dec 7, 2009 06:49 AM
Integra9000
Jan 28, 2008 08:37 PM
kevo1586
Nov 21, 2007 07:40 AM
danny98r
Mar 31, 2004 09:27 AM
Toretto
Jan 15, 2004 09:16 AM
