Suspension & Brakes Theory, alignment, spring rates....
Ground Control
Old Feb 8, 2007 | 09:28 AM
.I.Need.Money.'s Avatar
Default Ground Control
Well, I finally recieved my GC order, unfortunatly... the spring rates aren't the one's I wanted.
I went with 400f 350r. They sent me 350f 400r.
Should I just use these or should I send them back?
Old Feb 8, 2007 | 09:33 AM
Sean @ ESG's Avatar
are they coilovers or just springs? If they are coilovers can't you just move the front to the rear and vic versa?
Old Feb 8, 2007 | 09:42 AM
Tyson's Avatar
Default Re: Ground Control (93EGB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">Well, I finally recieved my GC order, unfortunatly... the spring rates aren't the one's I wanted.
Should I just use these or should I send them back?</TD></TR></TABLE>
um, theyre interchangeable...
Old Feb 8, 2007 | 09:45 AM
Default Re: Ground Control (Tyson)
Yes coilovers. It looks like the rear ones are longer. I dunno, maybe I was trippin.
Old Feb 8, 2007 | 09:47 AM
slammed_93_hatch's Avatar
just switch the springs on the perches. At that spring rate they should be 7 or 8 inch springs, which is fine swapping them around
Old Feb 8, 2007 | 09:49 AM
Default Re: Ground Control (slammed_93_hatch)
Good to know. Thanks.
Old Feb 8, 2007 | 10:03 AM
One more question. Am I supposed to mess with the snap rings on the Konis or should I just leave them as is?
Old Feb 8, 2007 | 10:43 AM
Tyson's Avatar
put them at the lowest setting. it wont matter much for adjustment range. just so that the top of the sleeves is as low as possible to avoid any collision with the top hat.
eluam
Jan 5, 2008 06:34 PM
ware
Suspension & Brakes
14
Aug 23, 2007 05:49 PM
stevey
Suspension & Brakes
Aug 28, 2006 07:31 PM
ekallstar21
Honda S2000
Sep 11, 2005 11:13 AM
aser1z
Suspension & Brakes
Aug 31, 2005 10:59 AM
