Suspension & Brakes Theory, alignment, spring rates....
Dynamic Caster
Old Jan 26, 2007 | 07:55 AM
vinuneuro's Avatar
Default Dynamic Caster
I was recetnly talking to another Prelude member about this. In the 5g Preludes, there's a major difference between the Base and SH models in where the radius arm mounts on the suspension side. In the Base, it connects to the lca, but in the SH the arm connects to the knuckle. Because of this, really the caster changes through the turning angle. Can someone comment on this setup, benefits/costs,etc?
Old Jan 26, 2007 | 11:43 AM
HondaF1Fanatic's Avatar
Default Re: Dynamic Caster (vinuneuro)
The higher the caster the more negative camber you will pick up while turning, and at least in my experience the more negative camber the better, at least on the track. My only real experience with this though is on a severely camber challenged car w/ MacP struts at all 4 corners. In that case it was generally thought that the more caster the better (Lots of people ran Whiteline ALKs or offset bushings). The negatives I noticed with more static caster was that on rutted or heavily crowned roads the car pulled a lot more in whatever direction the crown or ruts headed. Also, the car will lift on acceleration and dive on braking a bit more. I didn't notice a lot of difference from dynamic caster but that may because the rack on the car I drove (STi) wasn't the most communicative.
Jon
mikej94civex
Jan 24, 2010 07:19 PM
.water
Suspension & Brakes
11
Oct 23, 2005 08:24 AM
Tyson
Dec 1, 2004 03:13 PM
Spartanic
Jan 13, 2003 08:06 AM
