Suspension & Brakes Theory, alignment, spring rates....
5 lug conversion question
Old Feb 11, 2007 | 02:40 PM
TheWhiteHatchProject's Avatar
Default 5 lug conversion question
I currently own a 00 hatch that has a full GSR suspension swap. If i was to do the 5 lug ITR/CTR swap would I need to replace that entire swap with an ITR/CTR setup or could I just swap out the hubs and discs since I already have the GSR swap? I dont know enough about the GSR and ITR/CTR to know if I already have the components in place currently except for the hubs/discs or if I'd have to start back at square one. Hopefully this makes sense. Thanks
Old Feb 11, 2007 | 06:07 PM
BlueIntegraBoy's Avatar
Default Re: 5 lug conversion question (TheWhiteHatchProject)
You should order the full setup. By the time you order all the parts, remove the knuckles and trailing arms from the car, and pay for a shop to press in the new bearings, it will cost a little less, but more work.
If you order parts, you will need:
- Calipers
- Rotors
- Hubs with studs
- Bearings
rayrayx11
Mar 10, 2013 09:03 AM
ILLuSiv3
Mar 28, 2012 09:24 AM
Dena..23
Jan 3, 2009 01:29 AM
pine_apple45
Nov 25, 2008 01:53 PM
Dec 15, 2006 08:55 PM
