Suspension & Brakes Theory, alignment, spring rates....
Brake line question
Old 06-21-2007, 06:26 PM
JDM978's Avatar
Default Brake line question
i had a leak in my main brake line that goes from the front prop. valve to the rear it right underneath my passenger seat were it cracked. here the question can i just cut the section off and replace it with a high temp hose and camp the two ends will that be ok for the brake line?
Old 06-21-2007, 08:47 PM
Muzz's Avatar
Default Re: Brake line question (JDM978)
Personally i wouldnt, but if you do decide to go ahead and do it, id at least flare the lines where your going to attach the rubber tube, to help prevent the tubing and clamp slipping off. (like how intercooler piping has a ridge to prevent the joiners slipping off).
Old 06-22-2007, 07:42 AM
#1 Super Guy
94eg!'s Avatar
Default Re: Brake line question (Muzz)
No that wont work. The brake lines fluid pressure is much too high for any type of clamp fitting. It's just like your fuel lines. The high pressure feed to the fuel rail has special hoses w/ banjo fittings. Then the low pressure return line uses a simple clamped fitting.
Have it professionally repaired, or buy a whole new line from Honda and install it yourself...
Old 06-22-2007, 09:05 AM
DrSeuss's Avatar
Default Re: Brake line question (94eg!)
Replacing a rear brake line isn't easy. I ended up removing the subframe which wasn't a big deal since I had the motor and suspension off the car anyway and I removed the gas tank to get access to the some of the retaining clips. If you have access to a lift and can get the car up in the air, you might be able to weave it between the sub-frame and the body. Also the brake and fuel lines are grouped together running down the length of the car.
Old 06-22-2007, 06:29 PM
JDM978's Avatar
Default Re: Brake line question (DrSeuss)
thanks for the responds guys i guess i do it the rite way and get the pre bend line from acura
Old 06-22-2007, 09:44 PM
Hawkze_2.3's Avatar
I just ran all new lines to my front and rear calipers on my Prelude and it's not terribly hard... You definately cannot use any type of clamps or anything besides a properly flared line (I tried the clamps and failed miserably when I was a stupid kid, haha).
If it's hard to get a line from the dealer, which it may be, then I would suggest some pre-made lines from the auto parts store. All you have to is bend them and install them. I did all 4 in a day and a half including taking the rear subframe off.
justinball1717
Honda Civic (2001 - 2005)
10-24-2016 06:43 PM
ESP.net
Suspension & Brakes
05-29-2010 09:19 PM
hondazccivic
08-21-2008 11:41 AM
Soda Popinski
12-31-2005 12:28 PM
jolt-tsp
20
09-02-2003 10:10 AM
Quick Reply: Brake line question
