Suspension & Brakes Theory, alignment, spring rates....
camber question
Old Jun 22, 2007 | 02:15 PM
em1_racer's Avatar
Default camber question
if i lower my car 2.5" in front and 2.3" in back would i need to adjust my cambers?
wheels= 195/50/15
car= 2000 honda civic si
also would koni yellows or tokiko illumina go better with H&R race springs?
Modified by em1_racer at 3:35 PM 6/22/2007
Old Jun 27, 2007 | 09:24 AM
b18LS's Avatar
Default Re: camber question (em1_racer)
Your camber will be out if thats what you mean. with that amount, you'll be over 2 degrees negative probably 2.5 or so. Get an alignment and have your toe set to zero. Your tires will be fine, but might wear slightly faster on the inside edge with that amount of lowering. Always keep an eye on your tire pressure.....search a bit too man, this topic has been around for a while
em1_racer
12
Jun 22, 2007 09:04 PM
Bad-T
Dec 4, 2004 11:02 AM
redteg1
Dec 21, 2001 03:14 PM
George H
Oct 5, 2001 09:47 PM
