Suspension & Brakes Theory, alignment, spring rates....
damaged frame affecting alignment?
Old Apr 5, 2008 | 10:42 PM
whteteg8901's Avatar
Default damaged frame affecting alignment?
this is for a is300
car has been pulling to the right and the front tires have been wearing out on the inside so I took the car to the alignment shop hoping to fix the problem.
camber and toe are within specs but the caster isnt. What could be the possible fix for this? what suspension components can change caster?
car is salvaged (hit on the right side)
please help, ive changed the tires twice in two years already!
thanks!
Old Apr 6, 2008 | 01:21 AM
WhiteGSR95's Avatar
Default Re: damaged frame affecting alignment? (whteteg8901)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whteteg8901 &raquo;</TD></TR><TR><TD CLASS="quote">this is for a is300
thanks!</TD></TR></TABLE>
thats your problem.
whoever did the alignment didint notice if the frame is messed up or bent parts.?
Old Apr 6, 2008 | 03:45 AM
Reza^'s Avatar
take it to a body shop that has a laser frame rack and have them pull the frame back into spec , it will be easy to fix but the previous wreck is the culprit.
laser frame rack .. gl
Old Apr 6, 2008 | 09:35 PM
thanks guys ill check it out first thing
vinuneuro
33
Jul 26, 2008 08:44 AM
EG6R
Suspension & Brakes
May 2, 2008 06:03 AM
20ls01
Suspension & Brakes
Jan 11, 2008 01:52 PM
b16a2EBP
May 8, 2006 12:47 AM
jolt-tsp
Dec 27, 2003 11:47 AM
