[DC2R] GC + KONI Yellow, Spring Rates?
Hi All,
I'm about to purchase a set of Ground Control coilover sleeves, Koni yellows and top hats for my AUDM 2000 Honda Integra Type R (DC2R).
I plan on driving the car on the street mainly with 1-2 trackdays a year. So I need something that rides near stock.
Doing abit of research I have found the stock dc2r rates to be:
Front: 246 lb/in | 4.4 kg/mm
Rear: 140 to 246 lb/in | 2.5 to 4.4 kg/mm (progressive)
I only want to drop the car 15mm on my GC setup as practicality is a major concern of mine (Australian roads are really sh*t!!).
I'm thinking of running:
Front: 300 lb/in | 5.5 kg/mm
Rear: 250 lb/in | 4.3 kg/kmm
Your thoughts on this? I don't want to compromise handling for comfort either.
Anyone with a DC2R and the same setup have any recommendations?
Thanks in advance,
David
Thanks in advance,
David
if it were my car I would go with at least 350 front and rear, i have 380f and 330 rear on hatch but its lighter than the type r. I am only lowered like 1.5in max, it's stiffer than stock but its comfortable on the street , also keep in mind the stock rates on my car are lower than yours
hope this helps...some
Re: (choiboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choiboi »</TD></TR><TR><TD CLASS="quote">Why do you run same rates front and rear? are there any advantages of it?</TD></TR></TABLE>
more over steer and a more neutral feeling
i run 350/250 on my ls. this is a very comfortable setup if you set the dampening to full soft. setting it to full stiff, the car will be somewhat stiff. i think GC recommends 380 in the front to compensate for the heavy front of our cars. the stiffer the rear is, the stiffer overall your car will be.
stock type r I believe is 250f and 250r, keeping the rates the same front and rear would prevent you from upsetting the balance that the car has from the factory, I went with a lower rate in the rear so I could get a more comfortable ride on the street
Re: (egsleepercivic)
Thanks for the reply guys!
Torque-Correct GC recommends:
Rate: F-380 R-250 | F-6.8 kg/mm R-4.5 kg/mm
Drop: F&R- .75-3.5
egsleeper, you are right. However the rear is progressive. I'm aiming for neutral, inragards to handling.
I think I might go with GC's recommendations.
Drop: F&R- .75-3.5
Re: (sirg-vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirg-vtec »</TD></TR><TR><TD CLASS="quote">i have 450/350 rear. I actually enjoy riding in other peoples car. lol. </TD></TR></TABLE>
those were the rates i was looking at getting what is wrong with them are they stiff and do you have alot of under steer or over steer i will be having a 22mm rear sway i dont know if you have that or not
civexspeedy
12
07-24-2007 04:53 PM
ninetfivehatch
06-03-2002 03:59 PM
