Suspension & Brakes Theory, alignment, spring rates....
GC and Koni Yellows
Old 04-27-2008, 03:58 PM
ek4_b16a's Avatar
Default GC and Koni Yellows
okay, well i bought these awhile back, but not sure if i installed them on correctly. just coming on here to make sure i did it right, but lmk what you guys know.
i have gc's and koni yellows. wasn't sure if the sleeves are put on wrong, but are the taller sleeves for the fronts and the shorter sleeves for the rears? not even sure if i put the right coils on the right ends, but i'll have to jack the car up for pics. lmk...i'll post pics up if needed. thanks!
Soua
Old 04-28-2008, 02:04 PM
98vsmhatch's Avatar
Old 04-28-2008, 03:34 PM
GroundControlTrevor's Avatar
Default Re: GC and Koni Yellows (ek4_b16a)
shorter sleeves for the front longer sleeves on the rear
Old 04-28-2008, 03:36 PM
Default Re: GC and Koni Yellows (GroundControlTrevor)
Whats wrong with the setup anyways?
Old 04-28-2008, 06:21 PM
ek4_b16a's Avatar
nothing is wrong with the set up...just wanted to make sure, i might have put the taller springs in the back..maybe that's why it is a bit more bouncier even though i adjust the shock to be even...not too soft, not to stiff...i'm going to jack the car up to make sure i didn't do this...thanks!!!
Old 04-28-2008, 06:24 PM
ek4_b16a's Avatar
thanks for the pic too 98vsmhatch....got the same color and year...ahahahah...
Old 04-30-2008, 06:02 PM
EE2bitsk's Avatar
is that a better setup then like some teins or function and form full coilovers?
Old 05-02-2008, 06:54 AM
nicokpe's Avatar
haha something that good to know
Old 05-03-2008, 03:47 PM
crx(gator)'s Avatar
Default Re: (EE2bitsk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE2bitsk &raquo;</TD></TR><TR><TD CLASS="quote">is that a better setup then like some teins or function and form full coilovers?</TD></TR></TABLE>
teins/ff/d2 are garbage...
koni/gc are a great setup for cheap...
Old 05-04-2008, 07:48 PM
thursday's Avatar
whether they are better or not really depends on desired spring rates, an off the shelf valved koni can only handle a ~450-500 lb spring
i run koni/gc's and i love them
Old 05-05-2008, 02:48 PM
94VTECoupe's Avatar
Default Re: (thursday)
Please forgive me if this sounds retarded, I've never had the GC coilover springs before, although I intend on getting them.... But what is holding that sleeve on the shock? I've always seen "coilovers" like that sitting in a spring perch "cup" or whatever that's built onto the shock body before...
Old 05-05-2008, 03:57 PM
crx(gator)'s Avatar
Default Re: (94VTECoupe)
for the koni's there is a clip under the sleeves...
Old 05-05-2008, 06:16 PM
thursday's Avatar
if you look at the picture, more specifically the front struts (center ones) you can see the grooves below the red coilover sleeve. These grooves are for a c clip, and in the picture it is in the highest groove, the red sleeves have an insert that rests on this c clip, these are known as "koni ground control's"
Old 05-05-2008, 11:50 PM
94VTECoupe's Avatar
oh alright, that's a pretty sweet setup! I'm trying to lower my car a little bit more and want to get some ground control coilovers but my shocks have the spring cup so I was just making sure there wasn't something prohibiting their use on my setup.
Old 05-06-2008, 05:01 PM
legomytego's Avatar
whats the price of getting them serviced so they can handle a higer spring rate
808dc2typer
Suspension & Brakes
10
09-04-2015 05:05 AM
92integraVTECgsr
Suspension & Brakes
03-14-2008 11:47 PM
ieatrice
13
12-28-2006 09:34 PM
roberts
Suspension & Brakes
27
09-05-2006 08:55 PM
NTGR8D
03-10-2003 04:32 PM
Quick Reply: GC and Koni Yellows
