Suspension & Brakes Theory, alignment, spring rates....
93 cx drum conversion help
Old Oct 31, 2009 | 07:04 PM
Show15's Avatar
Default 93 cx drum conversion help
I have a 1993 civic cx with rear drums. I wanna convert to disc but I'm not sure what parts off of what integra I'd need. Any one know?
Old Oct 31, 2009 | 07:26 PM
nogo1231's Avatar
Default Re: 93 cx drum conversion help
rear trailing arms and disc brakes, ebrake cables, 40/40 prop valve, and a larger master cylinder(eg si or ex coupe) for best results
Old Oct 31, 2009 | 08:03 PM
Show15's Avatar
Alright. What integras can I get parts from? Just 93? Or any? And can I just take the booster and master cylinder from it too?
Old Nov 1, 2009 | 07:04 AM
phunhaus's Avatar
90-01 Integra
88-00 Civic
Old Nov 1, 2009 | 07:09 AM
Show15's Avatar
I can really pull from any integra? Like all trailing arms and bolts and what not match up?
Old Nov 1, 2009 | 09:05 PM
roastbeefrichie's Avatar
> phunhaus is right:
Originally Posted by phunhaus
90-01 Integra
88-00 Civic
yes, you really can pull a rear disc from any integra & it will bolt-up
(...like all trailing arms and bolts and what not will match up)
you'll need to get rear disc brake hoses since drum hoses are shorter
after you swap out the drums for the discs, you'll also need to get an alignment
the valve prop isn't a big issue, i ran mine on a drum prop and it was fine since most of your braking is done with your front brakes. if you decide to swap out the valve prop, source one from a non-abs w/ rear disc
time and time again, i hear ppl "advising" that a bigger m/c is needed for a rear disc swap. for the record...the size of your m/c is determined by the size of your front brakes (not your rear brakes)
if you haven't swapped out your knuckles in your 93 civic CX, you have stock civic DX front brakes (9.4" front rotors). general rule is…with your stock civic DX, with the stock front calipers, keep your 13/16” M/C. any bigger and your pedal will be too stiff
when you go to upgrade to a bigger caliper that uses a larger piston (ie., integra, civic ex, 99-00 civic si, itr, nsx, legend 2-pot, s2k, rsx, etc), THEN you'll need a bigger m/c because you are pushing more fluid through the brake lines
consider the crx si, del sol si & 92-95 civic si...they all come from the factory with 9.4" front brakes w/ rear discs on a 13/16" m/c
nogo1231, 2 different sized m/c's you're recommending here...
the 92-95 civic si (rear disc w/ DX knuckle brakes on 9.4" front rotors) used a smaller m/c (which is NOT any different than what the OP already has on his firewall, it's actually identical)
the 92-95 civic ex (drums w/ EX knuckle brakes on 10.3" front rotors) used a bigger m/c because of the bigger front brakes
g/l OP, let us know how this works out for you
Old Nov 2, 2009 | 10:17 AM
Show15's Avatar
Just wondering what's op? I've seen it used a couple times and know it's refering to me haha. I plan on picking up trailing and control arms off of an integra sometime this week. I'm going to get all the parts I need to upgrade such as rotors and and calipers new and high performance. This is going to take a little while but I'll piece together as I go. I'll keep you guys updated
Old Nov 2, 2009 | 12:57 PM
scottdh20's Avatar
op = original poster
Old Nov 2, 2009 | 01:03 PM
^^^OP is the Original Poster, person who started the thread (lol)^^^
ok, as far as rear lower control arms, the 90-93 integra DA & 96-00 civic EK are NOT compatible with your set-up (93 civic CX), it was cause issues when trying to align (the 88-91 civic crx EF, 92-95 civic EG & 94-01 integra DC will work). just use your rear lca's when swapping to rear disc.
Old Nov 3, 2009 | 04:44 AM
Show15's Avatar
Alright thanks
Old Nov 3, 2009 | 08:27 PM
glenniz's Avatar
Just give Brian a call at Fastbrakes.
He'll know the answer to all of your questions and he can supply you with all of the proper parts for your set up. He's only been doing brake swaps for the past fifteen years plus.
He won't cost you a fortune either.
Old Apr 5, 2010 | 05:47 AM
Show15's Avatar
Alright so I found a guy parting in integra. I was wondering what do I need to swap the fronts too?
Old Apr 5, 2010 | 09:48 AM
take the complete front knuckle/spindle with brakes from any 94-01 integra (or 92-00 civic EX, 99-00 civic Si, etc)
if you're upgrading your front brake system:
a. keep the brake booster from your 93 civic CX & use a bigger master cylinder from a 90-91 civic EX.
honda oem part # 46100-SH4-A11.
link below to b18c5-eh2's thread,"Easiest Brake Master Cylinder Upgrade Yet for 1992-1995 Civics..."
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/easiest-brake-master-cylinder-upgrade-yet-1992-1995-civics-364783/
b. grab the m/c & booster from the integra
Old Apr 5, 2010 | 03:47 PM
Show15's Avatar
Alright so if I wanna upgrade to integra brakes All the way around my shopping list would be:
rear trailing arms with brakes attached
teggy e brake cables
teggy rear brake hoses
front steering knuckles with brakes attached
teggy booster and mc (just for compatibility reasons)
teggy prop valve
Am I missing anything?
Old Apr 5, 2010 | 05:21 PM
new crush washers for the brake hoses
pads, rotors...
get a bottle of brake fluid
bench bleed the master cylinder
Originally Posted by BrakeExpert
after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
bed in pads/rotors
get an alignment
Last edited by roastbeefrichie; Apr 5, 2010 at 05:41 PM. Reason: 93 civic CX/ integra brake conversion
Old Apr 6, 2010 | 10:05 AM
Show15's Avatar
Alright so I'm thinking of upgrading the brakes when I get the parts to brembo blanks with hawks pads( I heard that combo is phenominal). But I wanna upgrade my calipers too. What's a good caliper? I'm thinking of going with a multi piston caliper but I dunno what is good for a decent price. Thanks in advance
94CDMeg
17
Jul 10, 2008 03:22 PM
spyderman_8_2
Jul 7, 2006 08:26 AM
skip122
43
Sep 2, 2005 09:35 PM
turbob16a522
Jun 22, 2005 03:46 PM
pane93civhb
Aug 2, 2004 10:02 AM
