Suspension & Brakes Theory, alignment, spring rates....
KYB AGX V.S. Tokico Illumina -HELP.
Old 10-19-2009, 01:13 PM
end005's Avatar
Default KYB AGX V.S. Tokico Illumina -HELP.
NOTE: If your comment/suggest is for me to get Konis, please, I suggest you leave.
My current setup blew. Pretty bad. I'm running Ground Controls and looking to replace my current shocks. I've tried searching (specifically between AGX V. Illuminas) and all I find are threads that start out like this then lead to suggestions to Koni.
Between the two (AGX/Illuminas) which is better the choice in terms of ride and quality? I understand both are adjustable (4 way-AGX, 5-way-Illuminas) and it seems that there is about a $50 difference between the two. Also, because my top mount is completely effed up, I was thinking about getting GC tophats. Is it worth it? Pros? Cons?
Car: 98 Integra GSR, daily driver.
Much thanks to all! Please leave negative comments out.
Old 10-19-2009, 01:39 PM
batallic's Avatar
Default Re: KYB AGX V.S. Tokico Illumina -HELP.
illuminas
Old 10-19-2009, 01:40 PM
batallic's Avatar
as for the top hats most ppl just run them on the front
Old 10-19-2009, 01:47 PM
end005's Avatar
thanks...but could you elaborate why the illuminas?
and yes, for the top hats, i'm just going to get the fronts if i decide to get them.
Old 10-19-2009, 03:03 PM
gtec8285's Avatar
i would go with the kyb agx as far as my experience, thats what i have on my 98 integra with skunk2 coilover and it rides good.
Old 10-19-2009, 03:24 PM
batallic's Avatar
illuminas warranty isnt void if u slamm the car, as the agx's are 1.5 max
Old 10-19-2009, 03:54 PM
Tyson's Avatar
illuminas have served me well.
its a quality shock. great for the price. compression and rebound adjust simultaneously, ive experienced that better for a wider range of spring rates and applications.
Old 10-19-2009, 08:45 PM
sayyoooon's Avatar
what prices are you guys getting illuminas for? everywhere i've looked they're either as much or the same as koni yellows shipped.
Old 10-19-2009, 08:50 PM
Tyson's Avatar
look on ebay. buy them direct from the sellers, new, with warranty.
Old 10-19-2009, 09:04 PM
sayyoooon's Avatar
the lowest i saw was $420 shipped, koni yellows are $450 shipped through THMotorsports :/.
Old 10-19-2009, 09:21 PM
Big Cat
fatboy1185's Avatar
Don't illumina's only have a 1 year warranty?
Old 10-19-2009, 09:52 PM
Tyson's Avatar
i'd still get illuminas over yellows. but thats kinda my thing. i dont expect everyone to agree.... the lure is strong for yellows. but whatever.
Old 10-20-2009, 01:25 AM
STOCK_SOHC_DX's Avatar
I have owned both, and honestly the perform about the same. Pretty good, but when warranty time comes around as mentioned above KYB does not warranty shocks when used with lowering springs.
Old 10-20-2009, 02:53 AM
sayyoooon's Avatar
i understand but i just dont understand the reasoning behind it. i'm truly trying to see the brighter side of illuminas.
Old 10-20-2009, 05:50 AM
end005's Avatar
Thanks for all the comments. I'm going to pair the new shocks (agx or tokicos) with my groundcontrols actually. I'm not sure if people saw that.
One thing that I have came across (while doing research on full coil-over systems) is the settings. On the AGXs, there are 4 settings - the Illuminas, 5. Is it possible that the 4 setting on the AGX is equivalent to setting 5 of the Illuminas? The reason I ask is I have come across a few posts which mention that the number of settings is somewhat a marketing scheme. The more settings, the more 'control' the customer has for example, Functionm Form Type IIs are 32 way adjustable. It was compared to a different coilover system which was 8 or 16 (i forget) way adjustable. A member stated that the '32 way' was simply just something to catch the consumer's eye, yet in terms of functionality, was equivilent to the 8/16 way.
Reading from both posts (t-i and h-t), it seems the population tend to favor the AGXs.. is it possible that both are equal, but people tend to go for the more cost effective one?
I have also noticed that not a lot of people pair the illiuminas with ground controls. Why is that??
Old 10-20-2009, 07:11 AM
Tyson's Avatar
funny, most ppl seem to prefer illuminas over agx around here from what i see.
dont just go by the number of clicks. quite frankly, the "32 way adjustable" is usually pretty crappy with limited actual adjustment range.
ive dyno'd my illuminas and they have a pretty wide range. i use them with ground controls. and the reason i like illuminas over konis is what i said before, because they adjust compression and rebound simultaneously, its better for a wider range of spring rates. ive used them with a lot of different spring rates.
Old 10-20-2009, 07:32 AM
end005's Avatar
Tyson, how are they? the pair... and what are your thoughts on the running the tophats on just the front rather than all four corners?
Old 10-20-2009, 07:38 AM
Tyson's Avatar
as for top hats, the front need it more than the rear for shock travel sake, but using top hats in the rear helps reduce the large amount of droop and looseness in the spring as you go lower static ride heights. its really not a problem, it just makes for a more tidy suspension.
i believe ive already vouched for illuminas enough. i dont know what more confirmation youre looking for. you havent been that specific yourself.
Old 10-20-2009, 02:54 PM
bmoua's Avatar
I've had both shocks before and the illuminas are the better shocks. The agx's too bad as well, they do job. I've pushed them pretty hard and the've held up okay. At the time i got a killer deal on them so i couldn't resist getting a set.
Old 10-20-2009, 03:01 PM
batallic's Avatar
https://honda-tech.com/forums/suspension-brakes-54/%5Bfaq%5D-shock-dynos-1104049/ shock dynos on both shocks
Old 10-21-2009, 06:17 PM
770_dc2's Avatar
sorry but this is kinda of a noob ? if u installed the top hats wouldnt it make ur car higher?
Old 10-21-2009, 06:42 PM
TunerN00b's Avatar
No change in ride height with an extended upper shock mount.
nyrican23
Suspension & Brakes
07-04-2007 03:34 PM
inlinesix
Suspension & Brakes
12-31-2005 09:58 PM
onesikcivic
05-13-2004 09:47 AM
Quick Silver
02-19-2002 02:10 PM
Duck Sauce
01-24-2002 09:35 PM
Quick Reply: KYB AGX V.S. Tokico Illumina -HELP.
