Suspension & Brakes Theory, alignment, spring rates....
pullin hard to the left
Old Nov 22, 2009 | 08:17 PM
dawgnuts's Avatar
Default pullin hard to the left
94 honda civic si hatch with a h22 swap and i have got a hard pull to the left after my alignment and i am trying to figure out how to correct this problem.. everything suspension wise is new including the rack and pinon ..i even replace the left axel thinking that would help .. the guy that did the alignment said it was a power pull or a radial pull .. so i rotated the tires and it still does the same thing .. any suggestions ? maybe a little differnet alignment setup..? i dont know sway bar or something ? i am in dier need to get this resolved .. thanks
Old Nov 22, 2009 | 09:03 PM
STOCK_SOHC_DX's Avatar
Default Re: pullin hard to the left
Post your alignment specs.
Old Nov 22, 2009 | 09:34 PM
dawgnuts's Avatar
i wll do that sir but it is going to be tomorrow ..but i will do that ..4 sure..thanks
Old Nov 23, 2009 | 02:05 PM
dawgnuts's Avatar
here are the readings
the front left -1.1 camber -0.8 caster -0.01 toe
the fron right -1.0 camber -0.7 caster -0.01 toe
the left rear -0.9 camber 0.08 toe
the right rear 0.5 camber 0.06toe
also front total toe -0.02 and steer ahead 0.00
rear total toe 0.14and thrust angle 0.01
i hope this helps out
Old Nov 23, 2009 | 03:45 PM
TunerN00b's Avatar
Well, it does show that at least something is very wrong. Caster should never be negative...
JNocon's Avatar
Did this problem happen before? Is it pulling to the left when you're driving or when you're braking? Can you post up the alignment sheet that the shop gave you?
Old Nov 23, 2009 | 06:22 PM
dawgnuts's Avatar
i will try
Old Nov 23, 2009 | 06:36 PM
TunerN00b's Avatar
Toe looks good.
Camber looks like the car is reasonably lowered, and looks fine.
Negative caster is bad, and can make the car wander all over the road. At least it is even left to right, but something is either bent or misaligned. Since its a 94 Civic, if the UCAs were flipped (left to right), the caster would have gone positive (about 1.5* more), so it probably isn't the UCAs. Maybe check the LCA bushings, LCAs themselves, and the subframe?
Old Nov 23, 2009 | 07:03 PM
dawgnuts's Avatar
well i did notice that the subframe has a little play in the alignment of the mounting points but not a whole lot maybe a 1/4 or less of movement i gues for some adjustablity..i just put a rack an pinon on it but it was doing this after the first alignment.. but about a year ago i got it semi aligned and it didnt do this at all and that alignment wasnt true speced out because i didnt have enuff adjustments to get it that close..so it just wore out a set of tires rather quickly..so everything except the right axle is new under my front end now and it is doing the pull thing ..it doesnt make sense to me at all ..
Old Nov 24, 2009 | 08:50 PM
dawgnuts's Avatar
anymore thoughts on this
Old Nov 24, 2009 | 08:57 PM
nokturnal_munkeeboy's Avatar
get lsd
Old Nov 24, 2009 | 09:08 PM
dawgnuts's Avatar
yea i got a hook up on one ..i was hoping it wasnt coming down to that .lol
Old Nov 24, 2009 | 10:46 PM
'00DC2's Avatar
i agree.. try to fix that caster. positive is much better. how's the sai?
sounds like torque steer. the h22a is a torque monster, hehe..
Old Nov 25, 2009 | 07:13 AM
hialeahzbg's Avatar
torque steer...
Old Nov 25, 2009 | 04:18 PM
dawgnuts's Avatar
well i have came to the conclusion that it is probally torque steer so im going to go with the lsd and all new bushings and new axles .. and if that doesnt fixit im going to burn it down...
Old Dec 3, 2009 | 11:27 PM
dawgnuts's Avatar
finally got it down to the bear essentials i replaced the pass side axel and boom no more pulling awesome ..but i did find some bushings that need to be replaced and im working on that as we speak.. so thanks guys ,,for the input i feel alot better about everything now..
Old Dec 6, 2009 | 09:02 PM
pi Ka chuuu's Avatar
lol after seeing ur alignment specs i was going to suggest that maybe its an axle issue since after all u do have an h22 in there =]
Old Dec 6, 2009 | 10:28 PM
dawgnuts's Avatar
i got all this coming so check it out ..ground control coilovers hard race lca hard race rcas .. and new front swaybar bushing set .. i am now looking for a rear swaybar for a reasonable price if any one knows where one is at let me know ..i trying to get a factory one but it doesnt matter much .. thanks guys
Old Dec 9, 2009 | 09:10 PM
GTlvr82's Avatar
Why would a messed up axle (not bent of course) have anything to do with how hard it pulls? I have a LSD in my car and it does the jerking/pulling thing pretty bad.
Old Dec 10, 2009 | 10:18 PM
dawgnuts's Avatar
i have no idea why it did that, but it did, and when i took out the old one and put the new one in it almost quit all together and that is cool.. still pulls a little but no more complaints
Old Dec 10, 2009 | 10:34 PM
.Manny.'s Avatar
Touching My Member
I can't say why exactly but I had the same problem with some eBay axles about two years ago. they developed quite a bit of play and the car pulled to the left on deceleration. Put in some rebuilt oem units and the problem went away.
Old Dec 11, 2009 | 01:16 AM
dawgnuts's Avatar
and my only other guess is that it wasn't dividing the power equally because of the dead axle and it was in limp mode
Old Dec 26, 2009 | 03:35 AM
APCXxstovetopxX's Avatar
yes if the left axle was binding up the trans would put more power to the right side causing the car to pull left
00IntegrAllmotoR
Aug 12, 2009 06:48 PM
stevanrk
25
Oct 1, 2008 09:10 AM
TurboEM1
Suspension & Brakes
10
Mar 31, 2006 05:12 AM
Batoutahell
Apr 20, 2005 05:11 PM
k-man
Aug 8, 2003 06:41 PM
