why does my skunk2 camber kit keep loosening while driving
only the passenger side keeps loosening up how is this possible is it actually jumping the threads?? or is it just spinning around loosening itself its the 88-00 civic ones
Re: why does my skunk2 camber kit keep loosening while driving
I wouldn't go so far as to say that. I've been running them for years without any issues. A year ago I had a really hard hit in the tire wall during a road race (side and rear) at 140 km/h and the uca's didn't budge... maintained alignment. Mind you these are the newer pro series balljoints that adjust from below.
im talking about the rear upper arms its getting looser and looser on my passanger side almost positive now
Are there lock nuts on each end of the arm to stop it from rotating and changing camber? I would scrap those unless S2 replaced the bushings with another material... those were definitely garbage bushings.
Take a picture of the arm so we can see.
its just backing itself out its not jumping threads cuz i tightend it up to the exact same spot as it was but this time i tightened the locking nut better i think.. well c in 2 days
It looks like you're missing the jam/lock nut on the inboard side so until you've fixed that, you'll continue to experience this problem.
Did have a shop install it?
no i had to take one off because i need more negative camber.. i had both the nuts off before with no problems but too much camber so i put one back on.. idk.. the other side is fine well c what happens
you have more room on the other side. so move the adjuster and locking nuts toward the outside of the car.
and the above post is win.
why would you need more neg camber? Rcomps?
The Grumpiest
hey i just orderd some xxr 527s there 8.25 15 inch and i am getting 165 45 15's there federal formoza fd1.. i have an eg hatch im pretty sure i need a camber kit for these to fit in right.. i was thinking eather buddy club or k sport or skunk2.. i have been researching a lot but if you guys could help me with this set up thanks
HT Black OPs
Please for the love of God ur not running a 165-45-15 size tire on a 8 inch rim.....
Those nuts are there for a reason, buddy.
wow.
"i took off the nuts that keep my camber kit from loosening, but why is it loosening?"
****ing facepalm
****ing facepalm
