97 civic no abs braking bleeding sequence
ok so i was always taught start with the furthest wheel then work my way to closest to the master cylinder.... but then i check honda service manual and this is what i got ..
WTH ... can anyone explain why after passenger rear ... followed by driver front ? could it be a typo ?
Re: 97 civic no abs braking bleeding sequence
so this doesnt fall under the " furthest from master cylinder" rule... because the master cylinder is right next to the driver front brake... this is so wierd
Attachment 526894
the prop valve does not mix together channel A and B
there are two channels going from master cylinder to proportioning valve
lets call them channel A and channel B
channel A will split off to front left and rear right
channel B will split off to front right and rear left
when purging/bleeding the hydraulic brake system you must do each channel separately
when starting on a channel you must do the rear first
the master cylinder is on the same side as the driver's seat (obviously, right?)
start with the diagonal rear brake
bleeding/purging order:
driver's seat on left RR, FL, RL, FR
driver's seat on right RL, FR, RR, FL
refer to this thread https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/proportioning-valve-channels-3194933/
refer to this thread https://honda-tech.com/forums/showthread.php?t=3194933
