Suspension & Brakes Theory, alignment, spring rates....
problem..
Old Jan 14, 2006 | 10:23 PM
jdmallstar2000's Avatar
Default problem..
i recently bought skunk2 coilover with kyb
agx's right and i notice the the spring rates on
the skunk 2s are 500 in the front and 400 in the rear
and in the box they look exacly the same... so i thought
maybe it dosnt matter.. so i installed them not knowing
which spring goes where.. and i put the sleeve all the way down on all 4
and the rear is alot higher than the front.. can it be that there is more
spring rate in the rear.. making it stay up..?? how can i tell which
spring goes where? noob Q i know dont flame plz. oh yeah its a delsol**
i got the skunk2's for a teg* Stiffer**
Old Jan 15, 2006 | 06:45 AM
Default Re: problem.. (jdmallstar2000)
bump
Old Jan 15, 2006 | 06:58 AM
ej0513's Avatar
the front should be 500lbs.. call skunk 2 though, did you try that? they can specify which spring is what for you.
a_benito86
Suspension & Brakes
12
Apr 5, 2016 05:09 PM
Makdaddynuge
Suspension & Brakes
Dec 6, 2005 04:02 PM
sirg-vtec
Suspension & Brakes
Sep 22, 2005 09:35 PM
sivik2nr
Jul 2, 2003 05:03 AM
austrian type-R
19
Nov 13, 2002 04:57 PM
