Suspension & Brakes Theory, alignment, spring rates....
Extended studs in front without using a press?
Old Jan 3, 2006 | 05:57 PM
beedoublejay's Avatar
Default Extended studs in front without using a press?
I have heard that there is a way of installing extended studs in the front without removing the bearing from teh hub. Is this true? If so how do I get teh old studs out and the new ones in?
TIA
BTW: The whole front brake assemblys are already off the car.
Old Jan 3, 2006 | 06:40 PM
88crxsir's Avatar
Default Re: Extended studs in front without using a press? (beedoublejay)
you can swap the studs w/o the press.
you need to take off the back brake dust cover, then you need to rotate the hub till you find a spot that is close to almost clearing the existing studs. hammer them out. you'll find the spot where they will do that. then use a grinder/ cutting wheel(heavy duty-makita) you must cut off half of the rounded head on the extended studs. don't worry it will be fine. this will need to be done to all of them.(extended ones only!!). use the same spot to slide the cut part facing towards the inner hub. you may need to tap with a hammer. after that you need a open lug nut for pressing the stud into the hub. it takes alot with your impact gun!!!!! thats pretty much it. i did it all by myself and it took some time, but well worth it.
Old Jan 3, 2006 | 06:42 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Newb
Old Jan 3, 2006 | 06:43 PM
Default Re: Extended studs in front without using a press? (88crxsir)
Thanks for the help man! BUT.....how do I go about removing the dust shield?
Old Jan 3, 2006 | 06:46 PM
Default Re: Extended studs in front without using a press? (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">Newb </TD></TR></TABLE>
Thanks Ryan...
Old Jan 3, 2006 | 07:04 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Cut them off, Kook
Old Jan 3, 2006 | 09:22 PM
I just went and looked at my frond brake assembly and it doesn't look like I can hammer the studs out anywhere. These are GSR brakes. Will it still work? Does anybody have pictures of what he is talking about?
Old Jan 4, 2006 | 07:15 AM
pictures?
Old Jan 4, 2006 | 07:35 AM
DC4_MADMAN's Avatar
Check sig.
Old Jan 4, 2006 | 12:36 PM
743power's Avatar
Default Re: (4door_demon)
you cant use the method 88crx described on cars with 10.2 or larger front brakes. It works on ef's I know, not sure about 9" eg or eks. . .
Old Jan 4, 2006 | 01:01 PM
Default Re: (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">you cant use the method 88crx described on cars with 10.2 or larger front brakes. It works on ef's I know, not sure about 9" eg or eks. . .</TD></TR></TABLE>
Damn. Thanks anyways.
Old Jan 4, 2006 | 07:36 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beedoublejay &raquo;</TD></TR><TR><TD CLASS="quote">BTW: The whole front brake assemblys are already off the car.</TD></TR></TABLE>
Buy yourself a new pair of wheel bearings and take them to a machine shop and have everything pressed in.... no worries that way
Old Jan 6, 2006 | 11:53 AM
743power's Avatar
Default Re: Extended studs in front without using a press? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Buy yourself a new pair of wheel bearings and take them to a machine shop and have everything pressed in.... no worries that way </TD></TR></TABLE>
Old Feb 28, 2006 | 05:49 PM
eGriDin's Avatar
yeah dude i got the front done...but is there a easier way for the back, because it looks like i have to take the hub out !...please help
Old Feb 28, 2006 | 05:51 PM
Default Re: (eGriDin)
The back is easy, just remove the wheel, breaks (disc or drum) and undo the 32mm nut. the whole hub will come off that way. Install teh studs and put it back together.
Old Feb 28, 2006 | 06:07 PM
slammed_93_hatch's Avatar
Default Re: (beedoublejay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beedoublejay &raquo;</TD></TR><TR><TD CLASS="quote">The back is easy, just remove the wheel, breaks (disc or drum) and undo the 32mm nut. the whole hub will come off that way. Install teh studs and put it back together. </TD></TR></TABLE>
did you end up getting your fronts done? if not let me know i can do them for you.
Old Mar 1, 2006 | 06:31 PM
eGriDin's Avatar
yah i got the front done, thanks (beedoublejay), but one more question, does that back have bearings or anything?. if so is it possible they might break, should i put new ones since im there..?
Old Mar 2, 2006 | 08:13 AM
The whole hub itself is a bearing in the rear, I wouldn't replace it unless you see damage when you take it off.
heyimrchills
Jan 3, 2010 05:43 PM
timmy0tool
10
Dec 19, 2007 03:25 PM
dc2woohoo
Aug 5, 2006 09:08 PM
sk8shorty012
Mar 16, 2006 02:39 PM
Cro-Mag
Jan 16, 2003 09:22 PM
