Suspension & Brakes Theory, alignment, spring rates....
rear alignment problem
Old Jan 10, 2006 | 07:02 PM
alwaysoverkill's Avatar
Default rear alignment problem
Had my car in for an alignment and the person said that they could not do the rear because the bolt was seized solid, even heat wouldn't loosen it.
Which one would I have to replace for rear alignment to be done, I just need to know which one to order.
- Get Omni LCA
- Get Omni rear camber adjuster arm
Old Jan 11, 2006 | 10:53 AM
Tyson's Avatar
Default Re: rear alignment problem (alwaysoverkill)
theres only one bolt in the rear for alignment. its the front compensator arm bolt at the chassis. this has nothing to do with the rear lca or upper arm.
as for it being seized, they really couldnt break it loose? i mean they came to the conclusion that its seized without trying so hard that it didnt break off or something?
Old Jan 11, 2006 | 02:17 PM
ya, they were scared to break it and I would not be getting it repaired there anyways (it was an Acura dealer here in Toronto)
I get an alignment when I lower the car in March and when I raise it at the very end of Oct for winter, so I want to be prepared for March, if its broken, what would I need to replace. Where is the compesator arm bolt attached too? I know how the front works and other parts, but i have no clue about rear alignment.
Old Jan 13, 2006 | 07:43 AM
anyone
e.p
Sep 13, 2016 10:41 AM
brownsEF
Feb 27, 2010 07:01 PM
project-boosteD
Suspension & Brakes
Jan 27, 2009 01:58 PM
PRoJecTSLeePaLoT
Mar 22, 2007 10:35 AM
gunnis
12
May 24, 2006 08:40 PM
