Suspension & Brakes Theory, alignment, spring rates....
toe problem
Old Jul 24, 2007 | 04:10 PM
ucc crx's Avatar
Default toe problem
i have a 89 crx si and resently swaped over a eg trailing arm to gain the disk brakes but know my toe is really bad. the front of the tires are pointed in. i tried to adjust it wear you normaly adjust toe from but it is maxed out. i went for an alinment today and they said they cant do anything about it. is there another way to adjust it
thanks
Old Jul 24, 2007 | 04:28 PM
Tyson's Avatar
Default Re: toe problem (ucc crx)
did you use CRX compensator arms? (good)
or the ones with the EG trailing arm? (bad)
Old Jul 24, 2007 | 05:40 PM
ucc crx's Avatar
i belive the eg ones b/c i just switched the two
Old Jul 24, 2007 | 06:57 PM
Tyson's Avatar
Default Re: (ucc crx)
then that would be why...
circapunk
Sep 26, 2009 12:53 PM
JDM Panda
Suspension & Brakes
Aug 3, 2005 02:49 PM
EG Power
Jun 11, 2002 11:04 PM
