Suspension & Brakes Theory, alignment, spring rates....
Alignment / Steering Problem
Old Aug 4, 2007 | 07:33 AM
EG6R's Avatar
Default Alignment / Steering Problem
My steering wheel is slightly off centered. I need to put in an 11oclock position for the car to go straight. Otherwise the car and steering will pull to the right.
Ive already had both front ball joints, lca/uca bushings and tierods replaced. Today i had it aligned:
Camber -1.5/-1.5
Caster (split) -.3
Toe 0/0
Ive also tried swapping my wheels fore and aft ; left and right. And they are already balanced.
It seems that the tug to the right is still there. What else could cause this?
Old Aug 6, 2007 | 06:06 AM
EG6R's Avatar
Default Re: Alignment / Steering Problem (EG6R)
Help
Old Aug 6, 2007 | 01:46 PM
JDM-SPECS's Avatar
did u check the alignment on the rear??? rear toe has 2 do with ur steering wheel positon
Domani99
Sep 5, 2012 04:29 PM
tonykdee
Honda Civic (2001 - 2005)
May 27, 2009 07:49 PM
EG6R
Aug 13, 2007 06:09 AM
Playa_FL
Mar 10, 2006 07:54 AM
WangChung
36
Dec 10, 2003 07:34 AM
