Front sway bar endlinks Civic ex
1995 Civic EX,
My front sway bar bushings are done for, I need new. I was hoping to go to autozone or discount and get them. But i need your help.
The stock sway bar(front) is 22mm correct? Can one help me find a link to the correct sway bar bushings and endlinks i need to buy from autozone.com? or somewhere i can get them fairly fast before I get an aligment...
is the front sway bar bushing easy to get to? I know the endlinks are cake.
Re: Front sway bar endlinks Civic ex (Guam_CiviC619)
these should be very cheap at the dealership, and will fit right.
slhondaparts lists them for $5.20 each.
generic aftemarket bushings can be a hassle. when i got a set of energy suspension bushings/brackets for the 24mm bar i was going to put in the front of my car, i found the mounting plate was too long and had clearance issues with some part on the chassis (i dont rememebr what, i havent had the car for a year and a half so memory is a bit fuzzy) that necessitated grinding off one corner of the plate.
95 ex had a 21mm front bar, not 22 like the 96-00 ex/hx did
edit: theyre cheaper in the link that guamcivic posted, ignore the slhonda price quote
Re: Front sway bar endlinks Civic ex (Voyage34)
so 21mm, right?
I should have said, I wanted to get ES endlinks , I just want to go to Autozone and pick them up, but I need help on finding wehat is the right one to get.
Re: Front sway bar endlinks Civic ex (Metal Head)
endlinks are easy, generic is fine. you may have to trim the spacer so its the same size as stock but thats not difficult. just did this actually for the rear bar on my brother's 240z
ES is fine for endlinks or whatever else autozone may have
