Suspension & Brakes Theory, alignment, spring rates....
Ground Control Problem
Old Sep 10, 2008 | 08:42 PM
rjones's Avatar
Default Ground Control Problem
I bought some ground controls from a board member. He never used them. I went out and got some tokico blues. The ground controls won't fit over the shockbodies. Now from what I can gather I need Koni Yellows to make them work. If this help at one end on every ground control there is a recess on the inside making an outside lip. What do I need to do???
Old Sep 11, 2008 | 05:46 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Ground Control Problem (rjones)
You need to get yellows. Or sell those and get their standard kit so they will work with your Tokico's.
Old Sep 11, 2008 | 08:14 AM
rjones's Avatar
I'll just get yellows from what I hear blues are like oem and will blow very quickly.
Old Sep 11, 2008 | 10:04 AM
Tyson's Avatar
you wasted your money with tokico blues.
even if they did fit, its a crappy shock.
theres nothing more you can do to make the "koni specific" GC fit if you dont have konis, other than get konis.
Old Sep 11, 2008 | 10:23 AM
GroundControlTrevor's Avatar
Default Re: Ground Control Problem (Tyson)
Post pics of the parts you have, I might be able to help you out.
Old Sep 11, 2008 | 11:34 AM
j_vision's Avatar
had this same issue and deided to go with the yellows...
its a decent ride if you decide to pick em up
Old Sep 11, 2008 | 08:43 PM
igone916's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjones &raquo;</TD></TR><TR><TD CLASS="quote">I bought some ground controls from a board member. He never used them. I went out and got some tokico blues. The ground controls won't fit over the shockbodies. Now from what I can gather I need Koni Yellows to make them work. If this help at one end on every ground control there is a recess on the inside making an outside lip. What do I need to do???</TD></TR></TABLE>
I run gc w/ tokico blues...To make it fit, just stick something in between the shock and sleeve to make hold it....mine works fine...hope that helps..
Old Sep 12, 2008 | 08:10 AM
mike-y's Avatar
Default Re: Ground Control Problem (igone916)
he could have the narrow tubes made for the konis. these fit very snug over a set of koni yellows, and probably wouldn't fit over a lot of other shocks.
RHGSR01
Feb 2, 2010 11:01 AM
guero2craze
Jan 11, 2007 12:07 PM
Daniel_san
Aug 17, 2004 12:26 PM
89civicdx
Jul 8, 2001 02:21 PM
