thicker coilover spring in front
Generally the beefier the spring the stiffer it is. Most coilovers produced on the market have japan type spring rates (heavier in the front).
Thicker coil wire does not always mean stiffer spring. Coil spacing and spring length also plays a part in the spring's actual rate.
Is there not a spring rate in either lb/in or kg/mm printed on the spring?
u2civic1
May 5, 2004 03:52 AM
